hey guys im finishing up my s14 sr swap in my s14. the other day i tried to start the car but my fuel pump isn't kicking on. i checked the pump direct to make sure its a good pump and it is it kicked on fine but when i plugged it back into the harness i get nothing. i checked the relay under the dash with a new one an no change. the engine turns over fine and everything else seems to work. any ideas would b alot of help.
Is the relay clicking ? Your going to have to pull out the Volt meter and start checking wires to fuel pump and relays..
Another very simple mistake and you might laugh, but make sure the ecu is screwed on tight... |
