Weird noise somebody help.
Started my car this morning going to work. As I left the spot i started hearing weird frinding and spinning noise. Right under my ashtray in the s13. Noise occurs in any gear with clutch in and out and in neutral, when the car stops noise dissappeares. ANother thing i figured today right after work while i am driving and ifi pull the ebrake the noise will completeley dissapear even if i pull the ebrake handle half way it will still dissappear.
So i am a little bit confused how can tranny spinning noise that is mad loud inside and outside can be related to the e brake or is it just and e brake cable that is loose and is banging on a driveline somewhere???
