Hi so i just bought some HIDs and i cannot figure a way on how to close the cover where the bulb is located because the wires get in the way. ive watched videos on utube and googled, but i cant find anything regarding on the kouki s14s. soo, help is needed! thanks
this is how i have the wires sitting right now. i tried to see if it was correct wiring. and it works! now just to find a way how to get those wires in.! |
I had the same problem. I was like WTF... So I just cut that rubber piece off and haven't had any problems with the seal on the inside.
Hold on I see what your saying now, mine is a rubber seal yours looks like hard plastic. I dunno... |
the piece i am holding where the positive and negative goes to is the plastic piece that is the cover to the headlight bulb. but the piece in the middle that keeps the hid wires together is a rubber piece.
well i got it done. i was looking at some retrofits, and found this one on hidplanet.
How-to: S2000 retrofit on 97-98 240SX (S14 Kouki) with that i used how they cut kinda like a hole to so the wires can come out and cap it back up. i cut the rubber piece and now my lights are in.! now to realign them. thanks guys |
