#1 | |
![]() Join Date: Feb 2003
Trader Rating: (289)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 289 reviews
Updated Oct, 28 2011 10:26am
Located:Oceanside and Orange County Clean S13 Differential Cover w/ Cooling Fins $35 s13 240sx Brand New Yamato Garage Rear Sway bar 28mmOne on Left, Just sway bar, No Bushings(You can use Tanabe rear bushings, theyre $20) $70 Sr20det Coolant Temperature Sub Harness w/ Broken Clip $10 each Stock SR20DET Intake Manifold Comes with both Intake Manifold gaskets in good condition, and whatever in picture, No IACV, No Throttle Body $40 Stock s13 Coupe Automatic Brown Seat Belt System w/ Ecu Rails, Belts minus driver belt, Ecu $40 s13 Rear Lower Control Arms Boots not in great shape $20 Regular Straight 2" Stock Hotpipe SR $10 Sr20det Coolant Hard Linew/rubber hoses $10 Stock SR20DET Thermostat $5 Front s13 240sx Stock 24mm Sway Bar. $15 Anything in these pictures $5 Set of 12x1.5 Tuner Lug Nuts w/ Key $20
![]() Quote:
#2 | |
bump #1. I thought the 5 lug would sell fast
![]() Quote:
yeah I guess so, I can help with that if necessary.
I would recommend getting nismo or morosso extended studs, theyre stronger. ARP doesnt make studs for this application. I can help with any questions. Sorry I dont have a hatch, and im not really into the widebody kits too much anyway. Not on my list of things to do right now. Thanks though.
![]() Quote:
#6 | |
Bump #2 for the upcoming weekend!
![]() Quote:
#10 | |
hi vincent sorry i sold the rear subframe a couple of days ago.
i also made a newer thread with updated items so ill update this one too. link for newer thread is always in my sig
![]() Quote:
