![]() Join Date: Apr 2012
All motor 500hp+ 1999 Camaro Z28/SS
Pictures HERE: http://imgur.com/a/FPVxe
I'm looking for a straight sale or TRADE for a daily. Car makes 402whp 363torque on the loaded Cunningham Dyno. For reference, a stock 2016 Camaro SS (advertised 455 flywheel hp) made 376whp on this same dyno. Not quite the same as the dynojets other people are used to. 63K original miles. Never been in an accident. Car built by Cunningham Motorsports. This car is an original SLP vehicle, with every option from SLP installed from factory (with paperwork). Car has every single piece of paperwork, going back to the original window sticker. Oil changed every 3K with Amsoil ZROD. Less than 3K miles ago: Thompson Motorsports 243 heads: 5 angle valve job, port, polish CMS custom big cam Comp Cam sprocket bolt retainer LS2 replacement chain BTR platinum dual spring kit BTR titanium retainers BTR stock locks BTR seats and valve seals BTR 5/16 7.4 pushrods Front cover gasket Front main seal Crank balancer bolt Adjustable melling pump Water pump gasket ARP unequal length LS head bolts GM head gasket LS7 lifter kit Fast 36lb fuel injectors Fast 92 intake manifold Nick William 90mm TB Smooth bellow Summit Racing LS1 induction pro packs Cunningham Motorsports tune Denso IP22 Spark Plugs Alpine Head Unit (All stock wiring intact and NOT spliced). I did this the right way with Crutchfield's complete metra kit. @59K miles: Air conditioning complete refresh and new parts including condenser ($800) Autotrix passenger fix kit (still in box) Solar Gard tint with lifetime warranty 2-way Autostart alarm, tilt, decibel, shock, ETC. Alarm system will be discussed with buyer. Racetronix fuel pump Fuel pump trap door STP Cabin Air Filter (as seen on LS1tech DIY) New Headliner Refreshed complete interior Whistler headlights New corner lights all around SS hood SS Spoiler SS spoiler LED lights SLP grill OEM C5 Alcoa Z06 Wheels 90% tires all around. 285/35 RS3 rears and 275/40 Goodyear F1 fronts Interior LED lights ZR1 Cyber Grey paint including door jams (3 year warranty) Optima Battery Founders Torque Arm Founders Torque Arm Relocation Kit Founders Panhard bar Founders Lower control arms Founders control arms relocation kit TSP 3’ headers TSP 3’ X pipe TSP 3’ Rumbler X exhaust ACT SPSS Performance Clutch (pressure plate, resurfaced flywheel) OEM GM slave cylinder Pinion seal, input seal, output seal Cunningham Motorsports tune and dyno WS6 short stick MSD wires ______________________________ I'm a bit in a jam needing to sell since my commute is a hour a day and as for now, the Camaro is my only vehicle. Car is dead spot on reliable. The whole motor has been refreshed when it got the cam and heads. It doesn't eat or drop a single spot of oil. Car's been maintained extremely well with paperwork. I'm a meticulous owner and this vehicle shows it. I'm just in need of a comfortable and automatic daily. Let me know if you have any questions or inquiries. Thanks! |
