StreetRacerMotorSports.com Free US Priority Shipping
![]() ![]() $95 Shipped US Priority AEM High Flow In-Tank Fuel Pump Features: Designed for high output naturally aspirated and forced induction EFI vehicles In-Tank design Tested to flow 320 lph @ 43 PSI 39mm diameter fits most applications Offset inlet design eases installation Each pump individually tested For gasoline vehicles (pump life may be diminished when used with E85 fuel) Kit includes fuel pump, rubber sleeve and end caps, pre filter, hose, clamps and flying lead ![]() $120 Shipped US Priority AEM High Flow In-Tank Fuel Pump Features: Tested and compatible with ethanol fuels up to E100, methanol fuels up to M100 and all types of gasoline Designed for high output naturally aspirated and forced induction EFI vehicles In tank design Each pump is tested to flow 320 lph @ 43 PSI 39mm diameter fits most applications Offset inlet design eases installation Kit includes fuel pump, rubber sleeve and end caps, pre filter, hose, clamps and flying lead ![]() $187.23 Shipped OVERVIEW AEM’s legendary Wideband O2 Air/Fuel UEGO Gauge unites unsurpassed accuracy, speed and control with an easy to read, digital interface. This gauge-type controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere. All AEM digital gauges feature a 0-5v analog output for use with data loggers and virtually any engine management system, such as the AEM EMS or FIC. ![]() $359 Shipped WHY YOU WANT ONE The AEM Water/Methanol Injection System comes loaded with more STANDARD features and high quality components than any other comparably priced injection system on the market today. The AEM injection kit comes with a 1 gallon tank with built-in low level indicator. The "Boost Safe" injection readiness system is standard in all AEM Water/Methanol Injection Systems. An integrated check valve in the nozzle prevents unintended fluid flow. One injector and two interchangeable nozzles are included to cover a wide range of potential horsepower levels and 20 feet of injection tubing facilitates installation on almost any vehicle. PRODUCT FEATURES 1 Gallon tank with built in low level switch Boost referenced progressive controller “Boost Safe” readiness safety system Check valve integrated into nozzle to prevent unintended fluid flow One injector and two nozzles to cover a wide range of HP levels High Pressure 200psi Recirculation-style pump Progressive Controller: Start Injection Boost 1-11psi. Full Injection Boost 6-39psi LED dash light for system status and low fluid warning 20 ft. of injection tubing Message us for more details or e-mail [email protected] |
