97 s14 Kouki with S14 sr20det
Sold -97 240sx runs and drives but needs tune to dial in
Eagle rods and arias piston Gt2871r turbo 550cc injectors Front mount intercooler 255 lph walbro Hks ssqv bov Apexi safc Enthalpy ecu 3" exhaust 6 puck clutch from Tennessee transmission Ac/heat Pbm comp coils 140k on chasis Unknown miles on swap Will not come with work vskf Issues: Rpm doesn't work and cluster doesn't light up. Probably needs new cluster. Need new hids. Passenger headlight got moisture. Dash bad shape. Cracks and dry rot. Sunroof works but leaks. Needs to be cleaned up. Does die out in neutral coasting down. I believe the safc need to be set properly. Sold ![]() ![]() ![]() ![]() Sent from my SM-G965U using Tapatalk Last edited by buuuddhhaa; 11-11-2020 at 05:42 AM.. Reason: Sold |
#8 | |
![]() Join Date: Jun 2007
Random but did you ever run this on the stock turbo? This will be very similar to my setup, minus the rods and turbo.
#10 | |
what type of HP did you make with it?
