S14 flca vs adjustable flca for s13??
Ok so I've looked and have not found anything. I have an s13 and want more negative camber on the front wondering if I should go s14 and run the risk of it not being enough negative camber or go adjustable flca? What's the max people have run on both? Any help appreciated just don't want to buy oem s14 and it not be enough camber.
Sent from my SCH-I545 using Tapatalk |
![]() Join Date: Dec 2006
LCA is 10mm Longer so it would give you a few degrees
後輪駆動車1番1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online #/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit Last edited by Sileighty_85; 03-08-2014 at 07:44 PM.. Reason: Fixing retarded information |
Shit my Bad, I meant to say the LCA is 10mm Longer so it would give you a few degrees
I knew something didnt seem right when I wrote that lol you will always benefit more from a Adjustable LCA though
If you do s14 Lcas remember you have to still run s13 ball joints if it's on an s13
