1993 Coupe, Automatic Cluster into 5spd Manual, work?
Hey all, I have a quick question
Sorry if this has been covered but I just couldn't get the answer from the search. I was wondering if an Automatic Cluster from a 1991 DOHC 240sx will fit a Manual 1993 DOHC 240sx Coupe? Mine wasn't working any more so I am looking for a replacement, is this swap a direct plug and play? Thank you very much! |
![]() Join Date: Dec 2002
I hope you die.
Cluster is the same for all 91-94 models.
![]() Join Date: Jul 2005
Sadly everything Russ says is true, hes been around a long time and has seen every question in the book over 100 times. I donno why people dont search before posting.
#6 | |
![]() Join Date: Dec 2006
not if its a hud, fuck nut. Quote:
see above. |
![]() Join Date: Nov 2006
Trader Rating: (54)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 54 reviews
^ What are you talking about? The HUD works in both manual and auto the same. As long as the harness is there and it's from the same year group then you're good.
So yes, Russ is right. All clusters for 91-94 work no matter if auto or manual.
- Jimmy Wanted: TBD For Sale: TBD |
![]() Join Date: Nov 2004
not trying to comercial post
but here is a list of everything you need Nissan 240sx - 5 Speed Swap - Enjuku Racing Parts, LLC
KA-T ORG-Function over Flush
![]() Join Date: Aug 2003
clearly you are. his car is already 5speed and his cluster is broken. why would he need 5speed swap part?
Drives a BRZ and is building a V6 S12 coupe. Last edited by irax; 10-28-2008 at 07:56 AM.. |
#10 | |
