Old 04-21-2010, 11:42 AM   #1
silviadrift87
silviadrift87 has a spectacular aura aboutsilviadrift87 has a spectacular aura aboutsilviadrift87 has a spectacular aura aboutsilviadrift87 has a spectacular aura aboutsilviadrift87 has a spectacular aura aboutsilviadrift87 has a spectacular aura about
17x10 +25 on front of 240sx?
anyone know how well these will fit? i have 20 mill fenders for the front. just wondering if they will rub. like the look of the concave, the 17x9 +15 i was planning to get doesnt have any. rear is 17x10 +12
silviadrift87 is offline   Reply With Quote
Old 04-21-2010, 01:08 PM   #2
JRex
JRex is an unknown quantity at this point
I'm running 17x10 +12 on the front with stock fenders. If you have coils you are going to need a small spacer for them to clear.
Never Due
JRex is offline   Reply With Quote
Old 04-21-2010, 01:15 PM   #3
Om1kron
Om1kron's Avatar
yes they will fit.
Wayne
Old 04-21-2010, 05:12 PM   #4
i need tires
i need tires's Avatar
i need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to all
Send a message via AIM to i need tires
Make the car fit the wheels, not the wheels fit the car!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i need tires is offline   Reply With Quote
Old 04-21-2010, 05:25 PM   #5
SUPERSTAR
SUPERSTAR's Avatar
Trader Rating: (18)
SUPERSTAR is close to perfectionSUPERSTAR is close to perfectionSUPERSTAR is close to perfectionSUPERSTAR is close to perfectionSUPERSTAR is close to perfectionSUPERSTAR is close to perfectionSUPERSTAR is close to perfectionSUPERSTAR is close to perfectionSUPERSTAR is close to perfectionSUPERSTAR is close to perfectionSUPERSTAR is close to perfection
Feedback Score: 18 reviews
I love you!!
"ARE YOU ONE'EM SKID RACERS?"
SUPERSTAR is offline   Reply With Quote
Old 04-21-2010, 05:38 PM   #6
KoukiMonsta
KoukiMonsta's Avatar
they will fit on my 240sx so give them to me
i have no clue if they will fit on your car considering i havent the slightest clue what year it is...
@UpshiftEngineering
Old 04-21-2010, 08:16 PM   #7
silviadrift87
that is actually exactly what i was thinkin. i oredered 17x10 +12 all around and ill do what it takes to fit em but im sure they will
Old 04-21-2010, 08:23 PM   #8
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
shiftdrift is an unknown quantity at this point
Feedback Score: 42 reviews
well if it hits the coilover, a spacer would be a better idea than hacking up a nice coilover.....
shiftdrift is offline   Reply With Quote
Old 04-21-2010, 08:56 PM   #9
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
Feedback Score: 115 reviews
Ok let me settle this once and for all. I know when I was going with the same set up I searched and searched and found little to no help.
Yes they fit on the front of a S13 and S14. S14 is probably easier, but I did it on a S13 with a bunch of "massaging". I run KTS coilovers and 5zigen FN01r-C's. I fit them in the front without a spacer. I just made sure that the wheel runs through the spring. If I rotate the spring it will hit the wheel, but I set it and put the weight down on the suspension and its fine.
I had to hammer in about 4 different places to make them fit without any rubbing at full lock. I just hammered it out, rattle canned it and its been fine ever since. If I get motivated I'll take pics of exactly where I had to pound, but overall you just keep test driving it and checking where its rubbing.
Old 04-22-2010, 06:48 PM   #10
silviadrift87
i have pbm coils and got fns to. i figured i might have to hammer a little but it will be fine
Old 04-22-2010, 06:58 PM   #11
DJPimpFlex
DJPimpFlex's Avatar
Or a lot.. I had to beat the shit out of my fender wells to get it to work properly with good steering angle. I should also mention that my car isn't what a lot of people on here would consider "low".
Old 04-22-2010, 07:08 PM   #12
Marcus
Marcus's Avatar
Trader Rating: (18)
Marcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfection
i have pbms also. i ran a 17x10+25 wheel with a 20mil spacer. the rim rubbed the spring with an 8mil spacer.
so, with no spacer and pbms. i garuntee you it will hit the coil. the rim probably wont even sit flat on the hub.
FIX::: space out your wheels a bit
if the problem is tire rub, then bang out your fenderwells.
but this depends on ride height and tire size.
are you dumped? fatty tires? crazy knuckles?
Marcus is offline   Reply With Quote
Old 04-22-2010, 07:15 PM   #13
DJPimpFlex
DJPimpFlex's Avatar
Ah that's another thing. I've been running 225/45/17 or 215/45/17 in the front.
Old 04-24-2010, 05:35 AM   #14
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
17x10 +25...no fucking way. No coilover out there is that skinny. From personal experience, even 17x10 +12 are hit or miss up front. All depends on the coilover. I had shitty MRs and I had to add 8mm spacers to clear the damn springs and collars. My Aragostas, I can fit 18x10 +18 and not rub on anything.
CLICK HERE!!!
Old 04-24-2010, 06:45 AM   #15
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
i ran 17x10 +18 f & r on my s13 with kts coilovers and zbrakes. hadta hammer the inner fenders and roll the outer fenders, but it cleared the coils no problem.
Old 04-24-2010, 11:02 AM   #16
eklips3
eklips3's Avatar
eklips3 is an unknown quantity at this point
in this case would a 45 profile tire rub ?
1992 240sx (RB20. [email protected])
eklips3 is offline   Reply With Quote
Old 04-24-2010, 01:40 PM   #17
brndck
brndck's Avatar
depends on how low your car is.
and what car it is.
and what setup you have.
and what time of year it is.
and if you have a giraffe in the car or not.
and if you love jesus or not.
