FS: S14 Tein C/O, Biki WC ECU, S14 Seats, VLSD, Cusco Mounts, Spacers, WG, Arms, MORE
Hi Zilvia! To start this FS thread off right here's an FAQ that should sort out any questions that you might have. Please read everything before contacting me
![]() Q: Are you willing to ship? How much for item x shipped to 99999? A: I'll ship anything that will fit in a USPS flat rate box. (https://www.prioritymail.com/flatrates.asp) Big parts like the coilovers and seats are already pending so I'm not inclined to ship them. My office is 5 minutes from a USPS branch so I'll ship within 48 hours of receiving payment. Q: I see that you have a neutral feedback. What's that about? A: I sold an A/C compatible top mount manifold to a fellow Zilvian and it didn't clear his A/C lines. I didn't see his feedback when he left it but we worked everything out after the fact. You can find lots of positive feedback (100% in fact) on evolutionm.net and northwestnissans.com, same username. Feel free to PM me on either forum if you want to validate ![]() Q: Do you have photos of item x? A: If I haven't yet posted photos for an item that generally means that it's not yet off of the car. I've posted dates of availability for a couple of items (such as the motor mounts and VLSD) and will take photos immediately after pulling them. Other items are straightforward enough that photos may not be necessary, but feel free to ask if it helps you make a decision. Q: Are these prices negotiable? A: Zilvia is the lowballing capital of teh Internets. I get that when you see a price you instantly believe that you can get the item for less; I'm not going to say no to a solid offer, but if I get 2 PMs about an item at the same time and one is willing to pay my asking price your PM may not get a response. Sorry. Q: I PM'd you about an item like 30 minutes ago and I still haven't received a response. WTF bro, I thought we were fwens. A: I'm busy. Like, really busy. Like, I waited a week to post anything here because my PM box is going to become a shitstorm busy. I'll try to respond to all PMs within a few hours, but please be patient ![]() Wow, you made it! On to the show: 1. S14 Tein HA Coilovers - Sold - Rates are 6k/5k, perfect for a daily driver that's also going to see some track duty. Includes pillow ball upper mounts/camber plates and helper springs! All four dampers are in good shape and provide what many ridealongs have said is a surprisingly comfortable ride, even on horrid north Seattle roads! ![]() 2. "WC" Bikirom ECU w/ Consult Port/Plug, Cable, Software - no longer available - Modified WC (Zenki S14 SR20DET) with USB interface, allowing for 16x16 ignition/fuel map modification, along with many, many other features. Similar to Nistune. Bikirom software included, along with USB cable (to interface with ECU), Consult port (to be wired into your ECU harness if you don't already have one), Consult plug (to interface with the consult port; used for data logging), and logging/interface software. Currently tuned for Z32 AFM, Cams, 550cc injectors, GT28R turbo, FMIC, and bolt-ons. Parameters can be easily changed to meet your needs, and anyone familiar with Nissans can tune this ECU. 3. OEM S14 Front Seats - Sold - In excellent condition with no tears. Matching rear seats can be added for $65, but I'm most interested in trading the rears for base model rear seats (with no pattern). Includes S13 front seat belt buckles. ![]() http://i.imgur.com/GzH6e.jpg 4. OEM S14 SR20DET Camshafts - $50 - Does not include cam gears. Removed from a head with only 35k miles. Includes both the intake and the exhaust camshaft. ![]() 5. OEM S14 Valve Springs/Retainers - $35 - Does not include shims. Removed from a head with only 35k miles. ![]() 6. OEM S14 Rear Upper Arms - $35 - Bushings are in good shape. Great replacement part for worn out bushings or swap to S14 rear subframe. ![]() 7. OEM S14 Rear Toe Arms - $25 - Bushings are in good shape. Great replacement part for worn out bushings or swap to S14 rear subframe. ![]() 8. OEM S14 Rear Traction Arm - $25 - Bushings are in good shape. Great replacement part for worn out bushings or swap to S14 rear subframe. ![]() 9. OEM S14 Tension Rods - $40 - Bushings are in good shape. Great replacement part for worn out bushings. Includes tension rod brackets. ![]() http://i.imgur.com/y9Vei.jpg 10. OEM S14 VLSD with Output Shafts - no longer available - About 160k miles on it, but still in good shape since the car was an auto for its first 100k miles. Only 2 auto-x events and one PGP event on it; remainder is DD. Does NOT include pumpkin or shims -- this is for the differential and output shafts only. Can include a 4.06 ring gear if desired, but you should use the one that you pull out of your open diff to match the mechanical wear of the pinion gear. (Will be available after 3/18) 11. Cusco Poly Engine Mounts (SR/KA) - Sold - About 5k miles of daily driving on them, just hardly broken in. Retails for $217 shipped from FRSport. Stiff polyurethane design for unmatched responsiveness. Compatible with SR or KA motors. (Will be available after 3/18) Cusco 223 910 A Engine Motor Mounts Kit S13 S14 12. OEM S14 SR20DET Engine Mounts (SR/KA) - Sold - In reasonable shape with some visible cracking. Plenty of life left, and can be filled with window weld after they're spent to get even more life out of them. Compatible with SR or KA motors. ![]() 13. ATP Turbo/Garrett 12-14psi Wastegate Actuator - Sold - Brand new! Excellent upgrade for T28 frame turbos; build boost faster and control it more reliably! Threaded adjustment rod to dial in desired boost. Retail is $85 shipped from FRSport. FRS Internal Wastegate Actuator 12-14 psi Upgrade for GT28RS ![]() 14. HKS Wastegate Actuator - no longer available - First generation version of the HKS actuator and used on a couple of my turbos now. Saw some boost spiking on a GT2835 (bottom mount GT3071R), so unsure of ability to control boost after 18psi; priced very low to reflect unknown condition. Retail is $147 shipped from FRSport. HKS 1430-RN005 Wastegate Actuator Kit S14 S15 SR20DET 15. S14 KYB AGX Rear Struts w/ OEM Springs - sold - In excellent condition with only 10,000 miles. Perfect for an auto-x car on a budget, or someone just looking to replace a worn rear suspension. Includes upper suspension mounts (also in great shape)! Retail is $280 shipped from FRSport. KYB High Performance AGX Shocks Rear Only Set 240sx S14 Clean red rears in the photo below ![]() 16. Summit Coilover Sleeves for Bilstein Struts (Pair) - $60 - Leftover coilover sleeves from when I was building my custom suspension. Will fit any Bilstein rear for those of you adapting 3000GT, Z32, or Evo rears. Includes sleeves, adjustable/locking perches, and top hats! One of the top hats has a small amount of rash, but is perfectly functional and will be exposed to the elements anyway. Retail is $70+shipping EACH at Summit. Bilstein B4BOA0000117 - Bilstein Coil-Over Sleeve Kits - Overview - SummitRacing.com ![]() 17. 5-lug Ichiba 15mm Hubcentric Bolt-on Spacers (Pair) - $80 - Run on my S14 for the last 5,000 miles and still in perfect condition. Includes all 10 beveled nuts, hubcentric rings, and the original box. Retail is $125 shipped from FRSport. Ichiba WS-25511466A Hubcentric Wheel Spacers 5x114.3 15mm ![]() http://i.imgur.com/vFdHm.jpg Last edited by kensuke; 03-30-2012 at 04:10 PM.. |
Good question -- it will probably come down to the orientation of the bracket and the design of the actuator rod. To be honest I'm not sure, and since these are advertised as actuators for T28s my gut tells me that it probably won't work.
Hmm well I see that they have a bracket on frsport for a t3 turbo. Maybe I should try the hks one first that way I won't be too upset money wise if it doesn't work out. It works fine right? Im not looking to boost past 18psi for a while to come...Lmk 480-510-6052 thanks
To be honest the condition is unknown, hence the $25 price. I ended up with boost spikes, but I don't know if it was due to the flapper not opening completely, a bad vacuum line, boost controller setup (AVC-R), or some combination of them.
I switched to an external gate rather than running the new ATP/Garrett wastegate that's also listed. This HKS actuator came with a GT2835 that I used to run. For $25 you're right that it's a low-risk purchase, and I should be able to fit it in a USPS flat rate envelope which would only be about $5. Call it $30 shipped and I'll eat the $0.90 PayPal fee. |
