![]() Join Date: Mar 2007
1st Gear No Boost SR20
I have near -0.6kpa vacuum at idle and hits steady 13psi under boost on all gear except first. I tried to push it on first and it just feels like all motor. I stopped revving at 5k rpm. Tried to search around but got mixed answers.
Some said it is normal since there is not enough load. I have following set up: stock s14 sr20 Defi boost gauge HKS acutator stock boost soleniod (correct vacuum) exedy lightweight flywheel stock exhaust tomei manifold others (not related to this topic) any comments welcome! Last edited by dongoesby; 10-19-2009 at 12:20 PM.. |
my sr run thru first feels like motor but it isnt... having a light flywheel will cause it to run thru the gear faster than your turbo spools... idk im just throw opinions
#6 | ||
sorry typo, it should say (-) in front of 0.6 kpa.
I've searched and -0.6kpa should be a fine number. Quote:
#8 | |
well, someone correct me if i'm wrong, but preeeettyyy sure the stock solenoid actually creates better boost response at lower RPMs. causing the turbo to spool faster. i'm sure there's some ill effect you're experiencing by using it with your adjustable wastegate actuator. i would say either test with a stock actuator WITH the boost solenoid, OR eliminate the solenoid. also, ar e you sure you have the right hoses going the right places on the stock boost solenoid?? what i think is happenins is that you are getting on the accellerator, and your wastegate is throwing your flapper open. you could also have the hks adjustable wastegate rod mis-adjusted. many variables. |
#9 | |
This all happened after I found out that my coolant system had air trapped in yesterday. It caused my exhaust gas temperature to jump sky high. Because of this, i never push the boost to redline. The EGT was 1200+ F 65mph hwy cruising and 1400 F under boost and eventually hits 1500+ F when it reaches 7k rpm at 14psi. I had only hitted 1500+ F once, and I have never tried it again. As after the coolant problem has taken care, the hwy cruising temp drops to between 1000~1100 F, and 1200~1250 F under boost, and below 800 F at idle. The car feels great now, feels more power and more smooth. And it solved my idle jumping problem too. I hope I didn't damage anything at the time I hit 1500+ F. I know it had reached to the level where it could melt a piston. |
#10 | |
![]() Join Date: Mar 2006
Bingo. Not enough load and you may be going through 1st gear too quickly to fully spool the turbo, especially without an EBC.
![]() Daily driven |
