What size oil cooler for the s14a auto transmission to use ?
As i installed an aftermarket aluminium radiator after my original was blown i discovered i need also an oil cooler for the auto transmission of my s14a.
What size/how many rows to use ? Some people tell me something too large may cause problems with the oil flow but what is the recommended size/ number of rows ? |
You're not towing with this car, something small will suffice. Below is to give you an idea. Make sure you get something with the correct sized hose ends.
http://www.jegs.com/i/Flex-a-lite/40...ductId=1122703 Mount it directly to your radiator. If you can, sandwich it in between your condenser and the radiator.
My SR20VET |
Thanks for the answear .As i bought a greddy 2 row radiator i don't think i can put it between the radiator and the condenser - i am thinking in front .
What about those type of oil coolers ? http://www.ebay.com/itm/16-ROW-AN-10...1b0c60&vxp=mtr Do i need something with a large main pipeline or those type will also suffice ? |
