![]() Join Date: Apr 2007
Trader Rating: (26)
240SX Garage Sale Los Angeles County Area!
Lots of stuff I would like to get out of my garage here. All prices are OBO. Parts are sold as is, no returns, you get what you pay for so ask for as many pics as you want and ask as many questions as you want =)
Next is a hotside from a Nissan Pulsar GTiR T28 turbo. It has been treated and coated (don't remember what kind, it was 2 years ago). The cracks in it have been welded, but still need to be machined down. These are 200 bucks from Garrett new. These are bigger than the s14 t28 hot sides and make a good upgrade if you want to make more power, should support up to 320. $50 1990 240sx 2 molding pieces from drivers side seat $5 take this junk from me please! Infinit Q45 front rotors, used, drilled for 4 and 5 lug, I believe it is about time for them to be turned. $40 S13 oem front brake lines , good no leaks. I might be able to provide hardware if necessary.$15 All sorts of good stuff here. Redtop SR intercooler pipe $5 s13 manual transmission mount $10 S13 rear brake lines (good no leaks) $10 T25 heat shield and bracket $15 redtop sr20det oem thermostat (good and working) $5 ka24de radiator cap $5 Brand new kragen brand q45 front disks, I paid over 100 for these special order, not drilled for 4 lug. $90 More stuff Wipers 2 front, one rear, I think 2 are Bosch, okay condition $5 ka24de automatic exhaust hanger (bolts to trans mount on the auto transmission) $5 3 rear strut caps, 2 fronts $5 Bracket for a s13 hatch jack in the rear left quarter panel $5 Sylvania head lamps (still works) $10 s13 240sx front abs calipers, comes with retainers and good pads $40 s13 non abs front calipers with all pads and retainers $25 q45 front calipers with all retainers and good pads $100 s13 rear hubs, not sure on bearing conditions lol $35 s13 non abs master cylinder with resivor $20 Nismo front s13 stainless steel lines, gives you a nice pedal feel, paid 180 new! $90 s13 rear dust guards for rear brakes $20 s13 rear hatch cover supports (2) $5 s13 e-brake cables $25 Omori Water Temperature Gauge white face, Celsius, paid over 100, comes with sensor. $90 GA16 sentra motor, just take it, needs a rebuild, comes with basically all parts. This was my first car project, I got it for 100 bucks and took it apart peice by peice in junior high school, good introduction to cars for someone who can not own one yet. Put it back together! I also have the repair manual for this motor, which is included. $5 S14 rear uppper camber arms (RUCAS) by Ikeya Formula brand new in box, cost over 400 new! $350 300zx brake booster z32 $35 Thanks for looking! Last edited by skylindrftr; 10-21-2009 at 12:25 PM.. |
![]() Join Date: Feb 2007
$10 I'll take this, if its the piece from the chassis to the tranny. (Cross member)
Nagasaki Motors![]() Friends help you move. Real friends help you move bodies. |
Trader Rating: (26)
ben277 your message box is full so here is your pm:
Sorry I don't have any of those parts except for the 4 lug hub. I could do $20 bucks for one picked up. |
Do you still have the rear hatch cover (trim) piece that I see in your picture I would like to buy it. How much do you need.Thanks reply to [email protected]
bump for you, my friend. good luck on your sale and see you soon!
#19 | |
460
