Odd SR20DET Injector Problem. Any ideas?
Ok so i went to go start up my SR20DET as i just built a new one and when i went to start it and begin the break in process it was only firing on two cylinders. So i did the obvious checked for spark- Good, checked plugs- Good. So then i went to fuel and what I found was the injectors for cylinders 2 and 3 were not firing. I had a new tune on an untested ecu so i switched the ecu with a known good one because i know some rom tunes end up frying injector drivers and had the same problem. This harness was not changed and had a sr20 in it running great before. I will begin to start tracing down from the injectors this weekend till i find the problem but wanted to know if anyone had any ideas on shortening that process. Thanks guys!
![]() Join Date: Jul 2011
Make sure the wires leading into the injector harness clips haven't pulled themselves free. I had it happen to cyl.4 on me. The wires all looked good but the ground wire had freed itself just enough to look like it was plugged but out enough that it lost contact with the injector. Hope that's it.
| injectors, problem, sr20det |
