Old 03-13-2013, 09:44 AM   #1
richmond82
richmond82's Avatar
richmond82 is an unknown quantity at this point
Talking 550CC Injectors, S15 SR480cc inj, DJetro, T3 Turbo, Throttle body tps, coolant hose
Interested in the following Trades -
S15 SR Head (cams not needed)
S15 SR Block (Bare)
Fuel Gauge and Sensor/Sender
EGT Gauge Complete w Sensor/Probe/Wiring
Power Steering Unit S15
Top Mount Precision 550CC Injectors $145 Shipped SOLD to #/f/members/urnext.html
Side Mount 2001 S15 Spec R 480CC injectors $250 obo
SR Injector harness with Bosch Style injector Clips $30
[IMG][/IMG]
[IMG][/IMG]
2001 s15 throttle body and tps $55 Sitting next to Q45 90mm for comparison
[IMG][/IMG]
Upper coolant hose (blue) with coolant temp sensor and complete wiring
$25
Stock S15 Sr20DET Spec R Manifold $65
[IMG][/IMG]
[IMG][/IMG]
TURBO SOLD
Thanks again
#/f/members/240dream.html
Turbo Used less than 200 miles at 9PSI $175 shipped TURBO FOR SALE IS THE t3 with the gold compressor cover
For the asking price included An10 45 Degree Hose End for oil return, 5/8 oil return fitting, oil feed with restrictor and Stainless steel feed line and the Polished Aluminum Intake Elbow coupler with 2 new tbolt clamps
T3 TURBO CHARGER .63ar
Intake: 3 inch
Inlet: 2 inch
Compressor trim: .50
Compressor Wheel diameter: 50.16 / 76.84
Turbine Wheel diameter: 54.06 / 65.20
Exhaust Trim: .63ar
Turbine flange type : T3 flange
Down pipe flange type: 5 bolt standard
Cooling type: oil cool only
Horsepower rating: 350+
Next to Garret GT 3076r .82 for comparison
Apexi Power FC DJetro S15 Sr20DET $350 SOLD to #/f/members/urnext.html
Comes with 3 Bar MAP Sensor
Air intake temp sensor
Hand Tuner
Needs RMA Apexi said cost will be between $125 - $600 if needing complete reman. However after taking to a electronics major he determined the ignition diode need to be replced. The ECU stopped working shortly after being wired in by Portland Speed Industries. ECU still communicates with car and cranks over. I am now running a Haltech Plat pro standalone.
RMA Submission
[IMG][/IMG]
[IMG][/IMG]
More to come
Drake: 95 Swapped S15SR Z32 Swapped TT 1991Vert
Last edited by richmond82; 04-08-2013 at 10:49 AM.. Reason: more parts added and title change
richmond82 is offline   Reply With Quote
Old 03-13-2013, 10:56 AM   #2
sr20ve620
sr20ve620 is an unknown quantity at this point
how much for injectors shipped to houston, tx?
sr20ve620 is offline   Reply With Quote
Old 03-13-2013, 11:07 AM   #3
richmond82
richmond82's Avatar
Wink
$145 shipped max
Old 03-20-2013, 12:24 PM   #4
richmond82
richmond82's Avatar
sorry for the lag in communication.
Old 03-20-2013, 12:57 PM   #5
240dream
240dream's Avatar
240dream is an unknown quantity at this point
interestied in your trubo, but it says 5 bolt but your downpipe is a v-band?
All I read was "I'm a little bitch and don't belong in this thread".
240dream is offline   Reply With Quote
Old 03-20-2013, 07:05 PM   #6
richmond82
richmond82's Avatar
it is 5 bolt we just had a 5 bolt/vband adapter flange for it, which i will def include for the asking price
Old 03-21-2013, 02:55 PM   #7
richmond82
richmond82's Avatar
Added all accessories that will be included with turbo at no additional cost. but dang at this rate i may just keep it for the Vert we are building lol
Old 03-22-2013, 07:08 AM   #8
240dream
240dream's Avatar
I pm'd you ready to paypal for the turbo
Old 03-25-2013, 02:06 PM   #9
richmond82
richmond82's Avatar
Thanks Again 240 Dream - Shipping was a beeyotch and i thank you for being Noble and helping out
TURBO SOLD
Old 03-27-2013, 03:51 PM   #10
richmond82
richmond82's Avatar
Added SR Injector Harness with Bosch Injector clips !
Thanks again 240dream for picking up the Turbo ! hope you enjoy many miles of boost Junkiness !
Old 03-29-2013, 06:43 AM   #11
richmond82
richmond82's Avatar
I would love to help eveyone out with these parts but do keep in mind shipping isnt cheap. Just sent off the turbo we sold on this thread. for a T3 shipped to CT was over $80... I literally made $80-$90 on the whole deal, which doesnt even cover the cost of the parts i had sold.
Enough Bitch Sessioning for me - just keep in mind when you offer less the item still has to be shipped so please be reasonablein your offerings
Old 03-29-2013, 09:45 AM   #12
TriniGT
TriniGT's Avatar
TriniGT is making a name for him/her selfTriniGT is making a name for him/her self
I may be interested in the power FC but have to think it through though.
TriniGT is offline   Reply With Quote
Old 03-29-2013, 10:18 AM   #13
richmond82
richmond82's Avatar
Cool. I may be open to trades if you have anything SR/motorsports related.
Would be a score if you picked it up and only cost $250 more to fix (for example) then you would have a Apexi certified PFC D-Jetro
Old 03-31-2013, 09:46 AM   #14
richmond82
richmond82's Avatar
All Parts still for sale Minus T3 Turbo
Old 03-31-2013, 04:50 PM   #15
x3thelast
x3thelast's Avatar
x3thelast is an unknown quantity at this point
clear your inbox please. trying to send pm
x3thelast is offline   Reply With Quote
Old 03-31-2013, 06:34 PM   #16
richmond82
richmond82's Avatar
sorry about that Buddy - Been busy working on harness deletion/rewire
Old 04-01-2013, 10:35 AM   #17
richmond82
richmond82's Avatar
Sale Pending on Power FC (complete kit) Precision 550's and SR Inj Harness
Old 04-01-2013, 09:11 PM   #18
richmond82
richmond82's Avatar
APEXI power FC (complete), 550 injectors and SR harness sold for a smokin combo deal to #/f/members/urnext.html
Thank you Come again...
Old 04-08-2013, 08:54 AM   #19
richmond82
richmond82's Avatar
S15 SR Block (Bare)
