![]() Join Date: Jan 2008
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 14 reviews
1990 s13 coupe silvia front, rebuilt sr20 and more.
the car is a 1990 240sx coupe, car is black, with black interior.
Exterior. Silvia front conversion with h.i.d stock body. the interior is stock with the exception of the nismo shiftnob, horn button, nrg quick release and momo hub, and sony cd player. and a blitz turbo timer. the engine and suspension -sr20 red top from an s13. with black top harness and ecu -circuit sports intake manifold gasket -nismo fpr -turbo xs exhast manifold -stock exhaust the car is good enough for street use and i have yet to receive a ticket ( knock on wood) and I have been pulled over a few times. - stock turbo with adjustable wastegate and custom bracket. -the motor has all new oem internals on the bottom end ( pistons, conrods, and the crank was balanced and polished) -s15 motor mounts -s15 turbo manifold gasket -acl race bearings -greddy hotpipe - arp headstuds, rod bolts, and mainstuds -custom grounding kit that works great -individually grounded coilpacks -cometic headgasket -act street clutch rated at 362 ft lbs and light weight flywheel. -the head has bean decked as well as the block -the head internals have been replace with new factory ones. So new valve springs, cam blots, valves, retainers, and valve seals and lifters, and rocker arms. - also has a gt spec down pipe -yoshio factory radiator -new coolant temp sensor - new plugs ngk iridium 8s -greddy airinx intake - all new gaskets from nissan -new fuel lines from goodyear and vacume lines -new goodyear gatorback belt - new oem oil pump and water pump -nismo thermostat -300zx fuel filter - altinator pully Suspension - d2 coilovers -secchi tension rods -peak perfomance rucas -peak performance rear toe arms -energy steering rack bushings -300zx front calipers with sloted and cross drilled rotors -project mu break pads -nismo wheel studs -steel braided break lines - 25 mm spacers( not pictured) -viscous lsd with 5 bolt axles and a 4.1 final drive - nismo clutch pivot the wire harness was tucked inbetween the intake manifold. I have had a few offers but I am asking 6,500 or best offer. I am located in socal in orange county. if there are anyquestions feel free to pm me or call me via my cell phone. my number is 949-232-8349 thanks. Last edited by IHasLongTorso; 02-03-2009 at 01:37 AM.. |
![]() Join Date: Apr 2007
I actaully dont like the silvia front ends but for some reason Im digging this car. Might be interested depending on how much i get from my insurance (theft) and if the cars still forsale when they come through. Anyways, bump for a sexy car
"I am Norwegian, and are not familiar with your urban words :P" |
![]() Join Date: Aug 2006
BUmp For a legit car and seller! YOu should've kept it, all that work and late nights and now you are selling it, Asshole!! Ill think twice about helping you at 3am next time you ask me to help you work on a car. LOL. GLWS!!
Im going to convince you to part out that long block.... just wait
PARTING/SELLING MY COUPE. PM ME. |
I'm not really looking for trades. I've been getting a lot of trade offers. I also have an aftermarket diff cover that holds more fluid and has cooling fins. It came on it from japan. I resealed it and put torco fluid in it along with the trans. call me or text me anytime. Day or night. Thanks everyone for all the kind words.
this car is back up for sale. Price is set at 6k obo. You can still call me about it anytime day or night. Let me know people. I know there is interest for this car as I still get texts and calls about it. Thanks The car was smogged in mid december so the smog is good until mid march. I'm sure this should help some of you interested in it that are worried about smogging it.
Damn, dude you should keep it. Why are you selling it? Don't tell me because of the economy.
Anywayz Clean coupe seen it in person and is cleaner. All you need are some wheels and the car will look dandy. Good luck with sale. |
#22 |
![]() Join Date: Apr 2003
Do you know how much the cylinders bores had to be bored to make them true?
Did you use stock size pistons and stock rings? (I know you said you used OEM but just making sure) And if so is there any blowby or oil consumption? Have you done a compression check and leak down test lately? |
#26 | |
#28 |
I don't think people realize that this isn't a stock sr with a painted valve covor. Just about every part of the motor has been replaced. All hardware is arp this motor is better than brand new. I keep getting offers of likr 4000 and I'm not going to put anyone on the spot but seriously. You can get a stock sr with stock body and no coils or z32 brakes and no coils. This car is at a great price. Someone pick it up. Whoever gets this won't regret it. Front mount and exhaust along with a boost controller and this thing will kill just about anything else with the same mods. Its fast than my buddies that has exhaust and a front mount boosting 14 psi. And this is only at about 9 psi. Imagine. Greatness. You buy now.
