so i've searched and cant seem to find a answer to my problem. my car wont start, i have fuel and spark. my car just cranks i messed with the maf, deleted the battery plugins, tps, and the distributor. i still have no start. any ideas are greatly appreciated.
#4 | |
![]() Join Date: May 2009
What do you mean by you deleted all that stuff? Do you mean you took it off or do you mean you checked all of that stuff and decided it is not the problem? Check your distributor and base timing.
the plastic connectors that come stock on them, i took that off and wired it straight to the battery terminal. have spark trought the distributor, just seems off. checking timing now but messing with the distributor did nothing.
