Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Electronics
Old 06-09-2011, 12:35 PM   #1
FRSport.com
FRSport.com's Avatar
FRSport.com has a spectacular aura aboutFRSport.com has a spectacular aura aboutFRSport.com has a spectacular aura aboutFRSport.com has a spectacular aura aboutFRSport.com has a spectacular aura aboutFRSport.com has a spectacular aura about
Send a message via AIM to FRSport.com
Talking FRSport: Defi DF04104 D-Gauge Black Face 52mm A/F Gauge Clearance!
Defi DF04104 D-Gauge Black Face 52mm A/F Gauge on Clearance!
On Clearance for $49.95!
Defi DF04104 D-Gauge Black Face 52mm Air Fuel Ratio Gauge
The D-Gauge Series were exclusive gauges for the USA which are derived from responsive
and highly-accurate Defi analog gauges. We have very limited inventory left of a few gauges.
D-Gauges feature dual bezels. The aluminum bezel is covered by a removable black bezel with
a red arrow on it. This black bezel can be rotated to indicate a warning value.
Features of this gauge include:
  • Stepping Motor drive: Quick Response and High Accuracy
  • Opening Mode inspires driving
  • LED illumination and illuminated pointer are uniformly bright
  • Maximum angle of deflective is 270 degrees and equally scaled on the dial
  • Bright transparent amber gauge dial
  • Black bezel with a RED arrow can indicate critical point
  • Self-checking open/short circuit on the sensor or sensor wire
FRSport.com || 18050 Newhope Street, Fountain Valley, CA 92708 (Map link)
Store Hours: Mon - Fri: 8:00 AM - 6:00 PM PST
[email protected] | 800-321-4747 | 714-515-4001 ext 146
FRSport.com Open Box Clearance Items
FRSport.com Weekly Specials
FRSport.com is offline   Reply With Quote
Old 06-09-2011, 02:51 PM   #2
LifeIsFantastic
LifeIsFantastic is an unknown quantity at this point
Does the guage come with all of the goodies needed to plug and play?
-Thank you
LifeIsFantastic is offline   Reply With Quote
Old 06-09-2011, 02:56 PM   #3
FRSport.com
Hi,
It comes w/ wiring and mounting hardware. It doesn't use a central control unit, you tap it directly to your existing primary O2 sensor. Here is some more installation info from Defi Defi - D-Gauge
thanks,
FRSport Team
Old 06-09-2011, 07:13 PM   #4
azienbabyboi
azienbabyboi's Avatar
azienbabyboi is an unknown quantity at this point
Send a message via AIM to azienbabyboi
how much??
azienbabyboi is offline   Reply With Quote
Old 06-09-2011, 11:12 PM   #5
Dsic240sx
Dsic240sx's Avatar
Dsic240sx is an unknown quantity at this point
Is this type of setup as accurate as using a wideband gauge setup?
Dsic240sx is offline   Reply With Quote
Old 06-10-2011, 08:48 AM   #6
Exas Spec D
Exas Spec D's Avatar
Exas Spec D is on a distinguished road
No. Tapping directly to your O2 sensor is considered narrowband. Unless your car is running a wideband O2 sensor from the factory.
Free shipping?
#/f/image.php?type=sigpic&userid=71648&dateline=123643  0746
Exas Spec D is offline   Reply With Quote
Old 06-10-2011, 09:58 AM   #7
240sxvaj
Trader Rating: (38)
240sxvaj is an unknown quantity at this point
Feedback Score: 38 reviews
(Correct me if im wrong)
this looks like a narrowband since it runs off your cars O2 sensor. narrowbands only reads when its hits a certain point for ex: if it hits lean it wont show you until you actually hit that point since it cant read anything in between, kinda of hard to explain unless you see a graph. all narrowbands are obsolete since it was used in the old days before the widebands came out.
240sxvaj is offline   Reply With Quote
