S13 dying over night but not dying after an hour.
Yesterday my car wouldnt start in the morning after 50 miles of driving on the new motor the night before.
If u have a current draw, u obviously need to figure out what it is which is easier said than done. Disconnect ur positive battery terminal and install an ammeter in between and see how much the car is drawing, then comes the fun part
start pulling fuses until u see ur amperage go down to figure out whats causing the current draw |
Altenator was replaced 2 days ago. I did blow a 75 amp fuse thats on the passanger side fuse box. I replaced it for now with a cable jumping both ends together waiting for the fuse to come in from nissan. Could that be the reason for it constantly getting power? Im not electrical savy at all.
![]() Join Date: Jun 2011
Not electric savy you say?
You blew a 75A fuse, thats pretty big. I get paranoid blowing 30A fuses as to whats going on in an electrical system. Take it to a shop |
![]() Join Date: Apr 2010
You should remove that wire immediately... there's a reason fuses blow... they provide a weak point so that if the power shorts, it'll blow the weak point instead of burning down your car (and your house if it's in the garage)
Sounds like you have a serious short somewhere... |
#8 | |
Have you tried just replacing the fuse you blew? |
I dis as one point and blew that one too. I actually know somebody who has that fuse area actually sauderes togeter which is the stupidest thing ive ever seen but
Its working find. I ordered a new fuse and am waiting for it to come in. |
![]() Join Date: Feb 2009
if you disconnected your battery and it still died then your problem is the battery. even if its a new battery it's not impossible to get a bad battery new. if you disconnected the negative terminal you should've still killed any possibility of it draining. as for the fuse yea i'd really be careful with that. i would check for continuity where you have that wire. if its shorted you could start a fire and thats not a fun time.
