![]() Just pulled a S14 KA 155 cold all cylinders 180 with a little oil. There is some rust in the coolant system from the previous older lady running water instead of coolant. Just wanted to ask how would I flush it all out?
Google it.
MRP Manufacturing |
Not a bad idea to run a coolant filter. I've flushed my coolant system about 8months ago and seeing rust particulates in the system again. I'll probably incorporate the coolant filter. Thanks for this.
![]() Join Date: Jun 2003
Trader Rating: (129)
and in the future, ONLY use demineralized water in your radiator, never tap water
(yes, you should use a glycol antifreeze in addition, not straight demin water. Mix ratio varies by location and weather conditions) |
![]() Join Date: Nov 2012
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 7 reviews
Fill with ONLY water, run engine. pull the lowe rrad hose at the radiator. drain refill run. and use water so you can just let it pour onto the ground. keep reflushing l;ike 3-4 times
