#61 |
Beautiful work, love the choice of wheels
#/f/chat/354550-nothing-easy-build.html |
#62 |
actually... new replacements... since obviously the CCW's were stolen... (couldn't go buy back another set, so I went to my next alternative)
#64 |
![]() Join Date: Feb 2002
Very nice selection.
For wheel locks, I recommend these... The standard MAG. Here is one of the many places you can get it: Amazon.com: Gorilla Automotive 63621 Standard Mag Guard Locks (12mm x 1.25 Thread Size) - Pack of 4: Automotive
Goals are dreams with a deadline. L.H.O.O.Q. |
#66 | |
#68 |
![]() Join Date: May 2011
are you running a single relay or dual relays (one for each fan)? Doing the radiator and fan swap this weekend and was thinking of one relay per fan to reduce the amp pull.
#70 |
thanks guys
#76 |
update later today
#77 |
Separated the engine from the cross member and front suspension to clean everything up and do some slight modifications to the engine.
Now that the engine is out and the engine bay was stripped back down. Took her outside to get scrubbed and cleaned, AGAIN. Now begins the process in making the car look pretty… first comes the paint… a low gloss white was applied to the engine bay alone (as the rest of the car isn’t ready for such awesomeness and attention). With the car making more power only mean one thing… more heat. So some gold heat foil was applied to the firewall (decided to do the whole firewall for aesthetics) and the driver side frame rail where dump tubes and exhaust transmit off heat. Had a hell of a time applying the foil as it didn’t like the paint’s surface… but oh well, car must go on! |
#80 |
Some grinding on the oil pan to clear the steering rack...
Carbonetic Twin Plate Carbon Clutch to transfer everything through the RB25DET transmission... ![]() |
#83 |
#85 |
lol, had to buy a new laptop for tuning... it had a webcam... so
hahaha![]() |
#87 |
| rawbrokerage, rb26, rb26dett, ross tuffbond, s14 |
