01-26-2020, 09:01 PM
#1
SR20 + S13 parts- Turbo, Nistune, Greddy, Suspension, LS Coils
- Cleaning out a bunch of old parts, prices are mostly firm unless you are buying multiple items. Will consider reasonable offers.
- Shipping is not included, will be shipping from 38104. Most stuff would be $10 to $40 to ship but I can get exact quote if needed.
- I have pictures of most items, can get more pictures if needed.
Best way to contact is via PM
Pictures included below, alot more pictures on my googledrive: https://drive.google.com/open?id=13W...arpbzx-2HIQ1Gt
- ISR Rear arms set, bearings have some play, ~20k miles of use: $150 --> $120 [SOLD]
- S14 SR20 WC ECU: $150[SOLD]
- Walbaro 255 fuel pump (~6 years old, worked fine when removed) one of the retaining clips is broken (see pictures): $15
- S14 Sr20 turbo with stock turbo manifold, Greddy divided outlet, DIF lines and fittings. Has some shaft play, on the higher end of spec (price reflects this): $350 -->$320 [SOLD]
- New T28 turbo inlet gasket: $10 [SOLD]
- DIF Oil and coolant lines (feed and return) for T28 turbo with all fittings etc.: $80 --> $70 [SOLD]
- Greddy divided turbo outlet: $80 --> $70 [SOLD]
- S13 stock rear arms with Energy suspension bushings and zerks fittings to allow proper greasing: $40
- S14 SR20 ?WC? ECU with Nistune Type 3 board installed, includes individual Nistune License and Nistune cable. (698 from Nistune): $450 -->$400
- Greddy induction kit for T28 bottom mount turbo with custom Aluminum air box (designed for S13), all wrapped in DEI Gold tape: $250 -->$220 ($180 without the airbox)
- OEM Z32 MAF, Wrapped in DEI Gold tape: $120 --> $100
- S14 SR20 intercooler kit with all piping and Greddy Type RS BOV, ebay intercooler: $200 [SOLD]
- BOV Recirculation setup for T28 turbo with Turbo Smart Kompact dual port BOV (Everything from turbo inlet to BOV included): $280 --> BOV sold, piping still available -->$120
- Ebay S14/S15 SR20 Intake manifold (typical cheap ebay quality, never installed, just test fitted): $40 --> $35
- Aeromotive FPR with gauge: $120 --> $100
- Unknown brand SR20 T28 oil and coolant lines: $40 --> $30
- Ignition coils from S14 sr20 with harness: $120
- 4x LS2 Ignition coils (I have 2 sets). $70, $120 for all 8. -->$60 for 4, $110 for 8
- Wiring specialties LS2 Coil conversion harness (New, never used): $100-->$90
- SR20 OEM Ignitor Chip: $40
- GREDDY PROFEC B SPEC 2 with solenoid (silver): $150 --> $130 [SOLD]
- Greddy full auto turbo timer with plug and play harness for S13: $100 [SOLD]
- Subaru STI 550 CC side feed injectors with modified SR20 harness to make this plug and play!: $130 --> $120
- ~4 year old Wiring Specialties S14 SR20 into 91 S13 Manual chassis conversion harness. Includes main and lower/transmission harness. Missing Alternator plug, and I modified the harness in a couple places. Sill plug and plan for S14 sr20 into S13. Can provide more details if interested: $250. --> $230
- Stock front brake pads for 2004 Honda S2000-one has brake grease on it: $50 [SOLD]
- Qstarz BT-818xt GPS receiver, 10Hz refresh rate: $50 -->$40
- No name turbo outlet pipe-dent on side and 1 damage and 1 missing stud: $20 [SOLD]
- Used ignition coils from 2001 VQ35 Nissan Pathfinder. $30 for all 6.
LS Coils and WS harness
Reason: Updated with sold items removed
