♛♛ Monday SUCKS ~ AEM EMS/AEM Electronics SALE || RB, SR, KA, 1JZ, 2JZ, 13BTT ♛♛
![]() Whats going on fellas? After the warm welcome the fellow community has given us and the awesome support. We have decided to run a AEM Electronics products promo $ale. I'll beat anyone's advertised price! Available for MOST cars, Just ask! PM me or Email me for more details! [email protected] AEM’s Series 2 Programmable Engine Management System is more powerful than its predecessor. In addition to more robust hardware, there are several improvements over the original EMS, noted in the chart below. Like its predecessor, AEM's Series 2 Plug & Play EMS plugs directly into a vehicle's factory ECU harness and requires no additional wiring or hardware. Windows™ compatible software (XP, Vista, Windows7) makes the task of copying, viewing and manipulating data as simple as a click of the mouse. Our new AEMTUNER software is infinitely adjustable software and allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately delivers proper amounts of fuel and correct ignition timing for any boost level or operating condition. ![]()
Digital Gauges WIDEBAND FAILSAFE GAUGE Wideband Air/Fuel and Boost in One Gauge! It actively protects your engine by constantly monitoring AFR curves and activating a user-defined failsafe strategy. It can save an engine from catastrophic damage. Displays both boost or vacuum and AFR or Lambda simultaneously on the same gauge Internal boost sensor Bosch Wideband UEGO sensor and weld-in bung included On-Board 3+ hour Datalogging capability at 20hz per parameter Full color Organic Light Emitting Diode (OLED) Display in center, user selectable feature (boost/vacuum or AFR) Intuitive set up software No free air calibration required- ever DIGITAL WIDEBAND AIR / FUEL GAUGE A wideband air / fuel controller and gauge interface in one unit! Bosch Wideband UEGO sensor and weld-in bung included Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers Does not oscillate AFR reading like narrow band sensors No laptop required for monitoring! Bosch sensor included TRU-BOOST GAUGE TYPE CONTROLLER Combines digital accuracy with manual controller-like ease of use! No external interface required for programming! Complete system includes harness, boost hose, on-board 29 psig pressure sensor (external 75 psia optional), boost solenoid, gauge display and all necessary fittings Quick connect technology eases the installation process WATER TEMPERATURE DISPLAY GAUGE A complete gauge system that includes a sensor and requires no additional parts. Gauge temperature range 100-300F Includes easy-to-install harness and sensor Complete stand alone gauge requires no additional sensors or programs to operate Ideal for both fuel injected and carbureted motors LED displays provide precise reference to critical operating TRANSMISSION TEMPERATURE DISPLAY GAUGE A complete gauge system that includes a sensor and requires no additional parts. Gauge temperature range 100-300F Includes easy-to-install harness and sensor Complete stand alone gauge requires no additional sensors or programs to operate Ideal for both fuel injected and carbureted motors LED displays provide precise reference to critical operating FUEL PRESSURE DISPLAY GAUGE A complete gauge system that includes a sensor and requires no additional parts. Gauge pressure range 0-100psi Includes easy-to-install harness and sensor Complete stand alone gauge requires no additional sensors or programs to operate Ideal for both fuel injected and carbureted motors LED displays provide precise reference to critical operating BOOST DISPLAY GAUGE A complete gauge system that includes a sensor and requires no additional parts. Gauge pressure range -30-35psi and -30-50psi Includes easy-to-install harness and sensor Complete stand alone gauge requires no additional sensors or programs to operate Ideal for both fuel injected and carbureted motors LED displays provide precise reference to critical operating OIL TEMPERATURE DISPLAY GAUGE A complete gauge system that includes a sensor and requires no additional parts. Gauge temperature range 100-300F Includes easy-to-install harness and sensor Complete stand alone gauge requires no additional sensors or programs to operate Ideal for both fuel injected and carbureted motors LED displays provide precise reference to critical operating |
![]() Join Date: Jan 2010
how much for a rb25 v2??
Guys if you placed an order Mon-Tues, They were processed today and being shipped out today as well.
Thanks again for everything! Those of you who havent, dont miss out on this deal! |
