![]() Join Date: Aug 2012
NEW Enkei PF01EVO Wheel In Stock - 18x9.5" / 18x10.5"
![]() ![]() ![]() ![]() ![]() ![]() ![]() Enkei PF01EVO Wheels - In stock in 18" 18x9.5" SBK Finish +12 / +22 / +35 - $499.50 shipped per wheel Order Here 18x9.5" Matte Black- $441 shipped per wheel Order Here 18x10.5 SBK Finish +15 / +22 - $517.50 shipped per wheel Order Here 18x10.5 Matte Black +15 / +22 - $450 shipped per wheel Order Here Center Bore: 75mm From time attack to drifters, the PF01EVO wheel is designed to maximize the performance of 18-inch tires. The PF01EVO wheel adopts ENKEI’s proprietary MAT process technology to ensure both the high rigidity and lightness required for an uncompromising sport wheel. Roulette Pattern - a special "roulette" pattern is designed on the inner lip to reduce slippage of the tire and the rim. This technology is also applied to Mercedes-McLaren Formula One wheels, also provided by Enkei.
Weights: 18x9.5" : 19.85 lbs 18x10.5" : 20.65 lbs http://www.youtube.com/watch?v=ecrZ6pGT3P0 Staggered setups available, just add two of each wheel you need to the cart and check out. We accept all credit /debit cards, Google Checkout, and PAYPAL. |
![]() Join Date: Jun 2003
Trader Rating: (129)
![]() goddammit why do they not listen!!! gimme these in 17x9.5 +15 and +0, and also 17x10 same offsets. |
![]() Full spec sheet: http://www.enkei.com/pf01evo.pdf |
We have the following in stock for the PF01EVO
