![]() Join Date: Sep 2012
s13 suspension question
ok so I seem to be getting a shake from the front of the car.. I had the wheels balanced and they were way off so I got that fixed. now the car still feels like Im hitting small (speed) bumps all the time it isn't as bad as it was but still doing it.. the car has adjustable tein suspension on it with tein tierods i'm wondering if maybe the alignment just needs to be done or maybe the rods aren't equal on both sides.. it doesn't shake when slowing down but the cars steering is very tight very minimal turning on the steering wheel and the car follows motion.. both good and bad I guess lol... any help would be great.. I even thought there might be a bad band in the tires but they looked and said they were good they did say there was a small flat spot on one of the rims but nothing they thought could cause a difference in driving...
I bet its that flat spot. My sisters FNO1RCs had a small flat spot and after we go that fixed the "speed bumps" stopped. Try another set of wheels and see if it does it with them. If it goes away its that flat spot for sure.
![]() Join Date: Nov 2010
Also having fully adjustable suspension you should be checking everything is tight every 6mos minimum. make sure nothing is loose down there that might cause a noticeable shakeyness
My experience working at discount tire leads me to believe you need some hub rings (if you dont already have some). Also, this may sound stupid but make sure your tires are still round. Your local DT should be able to tell you if you have excessive runout with the whole wheel and tire assembly.
