![]() Join Date: May 2007
Selling my almost new gt3071r.86. This turbo was used on my KAT for less then 1000 miles. ALL miles were brake in miles on the built engine that was still running off stock ecu and 270 injectors.. this turbo hasnt seen over 2psi.. its pretty much NEW.. still in NEW shape, NO SHAFT PLAY!!
It is the best flowing t25 flanged turbo from garrett.. it is a direct bolt on for the sr20det. Spools similar to a gt2871.86, but makes more power! I tacked the internal wg shut, but if the buyer wants to run the internal setup i can just drill the weld it.. its a tiny tiny weld also you can make this a true external gated t3 turbo just by swapping exhaust housings too... here are pics of my old KAT here are pics i took last night and as promised.. here is a video to show of great the shape of this turbo is... you cant see much, but it shows the wheel spinning perfectly find, and that there is no shaft play. price = 980 shipped WITH oil return fitting |
![]() Join Date: Feb 2006
legit seller who feel on hard time.. help a brotha out.
Mouth of the South There are a few mailboxes that have been looking at me the wrong way, lately. Nothing goes unchecked.
