![]() Join Date: Apr 2012
s14 ka part out, RHD clip and dash, other random parts
I am doing an sr swap and have a stock ka24de & auto trans out of a 95 s14. Along with that I have a 98 RHD front clip with HUD Dash (one crack).
let me know what you need I may have it. willing to ship anything at buyers expense. pm or text(217)819-8005 here are some pics of the clip/ i also have that stock s14 ka24de i can part out as well pics of that stuff soon ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() other random parts ka24de: starter alternator power steering pump ac compressor lower mani throttle body water pump thermo housing auto tranny with crossmember auto driveshaft auto shifter/trim stock exhaust s14 sr/from clip used water pump in good condition brake booster brake master cylinder power steering reservoir RHD steering rack minus lines RHD steering column RHD gas pedal RHD brake pedal (doesn't fit LHD) RHD dash glove box cluster bezel wiper switch RHD wiper motor/linkage RHD cowl cover plus a bunch of other parts, if you don't see what you need just pm or text parts either sold or don't have: ka upper intake mani ka head/cams/valve cover ka intake ka maf sensor ka fuel injectors and rail RHD wiper arms rhd ac trim rhd column trim kick panels ka ecu rhd headlight/turn signal switch lhd clutch pedal Last edited by Typecast; 06-19-2012 at 10:33 PM.. Reason: updated list |
![]() Join Date: Mar 2009
There is a sensor on top of the tranny by the motor. There is a small wire that unplugs from the sensor, and then unplugs from the lower harness about 8 inches down. I need that wire. will you do $5 shipped to 40220?
