![]() Join Date: Aug 2017
Shifter Spring?
I went to install my short throw on my s13 and when I unbolted the middle bolt closest to the drivers side of the car, a spring shot out at me. Long story short, I installed the shifter and forgot the spring. What does the spring even do and is it important?
I believe that there is a spring on either side of the shifter to help center it. For example, when doing the side to side "wiggle" to check if its in neutral, the resistance you feel comes from those springs.
![]() Join Date: Oct 2013
The springs on the sides of the housings help reduce side to side slop. They are important yes. A few companies make upgrade kits, and I remember the ka-t.org guys had figured out home depot springs that worked.
I put slightly stiffer ones in my trans and it feels much better. |
![]() Join Date: Nov 2012
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 7 reviews
I dont fully understand how that one works yet. i got a couple of these trans ive taken apart and still have no idea what that spring does
what i do know it is pushes against one of the pins that center the shifter BUT it pushes against that pin perpendicular Would love to know what it actually does ![]()
The Game you lose haha |
![]() Join Date: Jan 2010
#12 | |
Looks like it’s somewhat important lol, So this spring does go back into the middle drivers side shifter bolt hole? |
#13 | |
I think it goes next to the driver side middle bolt hole. it should have its own separate hole. like I said looking at it almost doesn't look like it does anything. so its really hard to say. but I assume its must be important lol it may have something to do with preventing you from bumping your shifter into reverse on accident but idk that's all I can think of
#14 | |
Got ya, thought so. Thanks man |
