Fs:1988 RX-7 Convertible, 65k original miles, 5spd, exceptional condition
SOLD
Exceptionally clean car. Driven monthly. Annual maintenance. Garaged. No rust. Selling to clear space in my garage and focus on my Nissan projects. Very minimal modifications using only high-quality or OEM parts. Zero mechanical issues. Jump in and drive it home anywhere in the US. Tags just renewed through Dec. 2020. ![]() ![]() ![]() ![]() Full Gallery: https://imgur.com/a/P8x7WUy Additional pics from November 2015 when I purchased the car in California. I drove it down the coast and across the Southwest out to Colorado. Leather bra was installed just for this drive to protect the front end. Was removed and sold soon as I got to Colorado. https://imgur.com/a/xRpLlHn Specs: 1988 RX7 Convertible VIN: JM1FC3519J0102936 Clean Carfax 65,XXX miles Original 5 Speed car Original convertible top in mint condition Past two owners have run premix Always garaged with battery tender Never driven in heavy rain or snow Zero mechanical issues Exceptionally clean chassis Original manuals included Fully optioned, including: Blue leather interior (no cracks, no tears, seats conditioned twice a year) Blue vinyl convertible top cover in excellent condition 3 Spoke Leather steering wheel Tilt Steering wheel Illuminated Ignition keyhole Original (and fully working) A/C Original (also fully working) Cruise Control Other Standard features on the RX7 convertible: 15" BBS wheels Color-matched electric vented mirrors Power antenna Power steering Tinted windshield sunshade Theft Deterrent System Power windows Power convertible top with removable Targa section (no tears, no leaks, no issues) OEM Blue vinyl convertible cover (also no tears) Larger Turbo II brakes standard on convertibles Engine: HKS panel air filter installed at 64,000 miles in 2017 All original and working emissions and exhaust, car has never failed an inspection. Just passed emissions inspection Dec 2019. Oil + filter replaced annually Most recent oil change in Fall of 2019 as well as full mechanical inspection at Mazda dealership Thermowax Replaced @ Rotorsport in 2014 Fuel Pulsation Damper eliminated @ The Shop in San Bruno in 2014 4oz Idemitsu Rotary premix added with every fill up since 2015, prior owner also premixed. RotaryBum Premix bottle/funnel kit included. Suspension/Brakes: Replaced old squeaky shocks/springs with Japanese Cusco Street Zero A Red Coilovers (6k/8k) in 2018. These were built to spec and purchased through Cusco Japan via RHDJapan. Racing Beat sway bars installed by a previous owner OEM BBS Convertible wheels with caps and wrench Sumitomo tires installed in 2014 @ 60k miles OEM Turbo II brakes with red calipers Brake rotors/pads replaced in 2014 at 60k miles Exterior: Rolled inner rear fenders Used ?€˜89-?€™91 S5 Convertible tail lights in excellent condition installed in 2015 Original OEM S4 tail lights (excellent condition) included New Raybrig Headlight housings installed in 2017 New Raybrig H4 RS-C clear white headlight bulbs installed in 2017 All original OEM glass, including windshield Interior: Used OEM ?€˜89-?€™91 S5 shifter installed in 2016 New OEM shifter bushings installed in 2016 New Weighted S5 Black RE-Amemiya shift knob in 2016 Original OEM S4 shifter and shift knob in excellent condition included New Alpine CDE-170 CD/USB Head Unit installed 2019 (pics show an Alpine CDE-143BT, I just swapped that one into my 300zx and installed a new CDE-170 in the RX7 here) New Door Speakers: Rockford Fosgate R1675X2 6.75in installed in 2016 New Dash Speakers: Rockford Fosgate (model unknown) installed by previous owner New StockInteriors.com floormats in Steel Blue Plush cut installed in 2017 New Warm white (similar color to incandescent) LED map light installed in 2019 Replaced a few cracked dash vents & demister with new NOS OEM Blue Mazda pieces from Atkins Rotary in 2017. Notes and nitpicky details: - Minor (non-collision, see carfax) damage reported in 1992 to passenger side fender and small dent in A pillar (near mirror). I had the fender and dent near the mirror fully repaired and paint matched in 2019 at Precision Auto Works in Broomfield, CO (pic from before repairs in gallery). - Small chips in paint & clear coat visible up close if you know where to look - Rear passenger fender paint cracked under fender lip, not visible, not peeling - Windshield wiper sprayer is weak (despite newly rebuilt relays and newly installed pump motor in 2019) - Windshield wipers do not operate on intermittent mode for whatever reason (despite new relays). They work fine in regular mode. - Car hasn?€™t been driven in rain for the past 5 years, so this hasn?€™t been an issue - Headrest speakers non-functional - Wiring was cut by a previous owner. This is probably an improvement over having the tiny 30yr-old speakers blaring right behind your ears. - Stereo runs on Door and Dash speakers (both newer Rockford Fosgate units) - Drivers vinyl armrest in door just starting to get a bit wavy - Minor carpet color fading on door panels - Crack in passenger interior plastic behind seat (not noticeable unless you're looking for it) - Passenger power window motor a little slower than drivers side, still fully functioning - Brake booster leaked at some point prior to my ownership and created minor surface corrosion in driver's side rail of the engine bay (also not noticeable unless you're looking for it) - Engine leaks a couple drops of oil each time it is parked, just haven't had to the time to locate and seal it up - Shift return spring needs replaced (common 2nd gen RX7 issue, does not affect/impact shifting), replacement spring included - File folder full of receipts and records included Carfax History (latest report does not go all the way back to 1990, I still have the details):
@mdnt_32 | Jan 1990 TH1 BNR32 | Jan 1990 TH1 Z32 Last edited by Citrus; 04-07-2020 at 06:52 AM.. |
