I recently bought a used DOHC cluster. The needle in the ad was a normal resting position, but when it arrived, the needle is buried all the way to the right.
Is this a sign that it's broken? Any pointers on a fix. I searched and only found one item with a similar issue and no resolution. http://www.240sxforums.com/forums/be...s-go-fast.html |
