Old 09-19-2007, 12:51 PM   #1
yaba94070
yaba94070 is an unknown quantity at this point
Send a message via Yahoo to yaba94070
97 kouki w/fully built Sr20det FS
I am selling my car as is for 15K... i would like 20K for it and i will finish the car. The chassy has about 130,000 on it. the motor only has 268 miles. Its still in break in period. i dn't drive it at all. i have never reved the motor pass 4000 rpm... i baby th ecar thus the low milage on the motor. I have spent 12k on the motor alone, not including the rest of the car....
heres a mod list
there may be some things missing
S13 Blacktop SR20DET
GT2871R .64
Z32 Maf
Tomei 740cc Injectors
Apexi 1.1mm Headgasket
Built Head/Port n Polished w/1mm oversized valves
Crower Valves
Crower Valve Springs
Crower Titanium retainers
Crower Rods
Crower Stage 2 Cams
CP pistons 87.5mm
ARP 2000 rod bolts
ARP main bolts
ARP Gead stud set
ARC Cooling Panel
ARC 1.5bar Radiator Cap
Clevite Rod Bearings
Walbro fuel pump
Nismo/ Tomei Fuel Regulator
Nismo Thermistat
HKS Super Sequential Hot Pipe
HKS Downpipe
HKS Super Sequential BLOV
Blitz LM FMIC
Blitz LM Intake
Blitz Nur Spec Exhaust w/ test pipe
Koyo Aluminum Radiator
Samco Radiator Hose
Flex-a-lite dual fans
New(forgot brand) Water pump
Greddy Lighter Pulleys
Greddy Plenum Cold Pipe
Greddy Intake manifold
Greddy Rocker Arm Stoppers
Greddy Oil Filter Relocator
Greddy Oil Pan
Greddy Turbo Elbow
Greddy Oil Catch Can
Greddy Oil Cooler
Electronics:
AEM Engine Managment System
Apex'i Pen turbo timer
Apex'i SAFC II
Apex'i AVC-R boost controller
Autometer Dual pod gauge
Greddy Boost guage
Greddy Oil Pressure gauge
Greddy EGT Peak/Hold
Suspension/wheels:
Megan Racing Coilovers
MR Front Strut bar
MR Rear Strut bar
MR C-Pillar Bar
Phase2 Aluminum Subframe bushing
Tein Tension Rods
Tein Tie Rods
RUCA
Peak Performance 60mm Front Studs
8mm Spacers
5zigen FN01RC 17x10 +12 all around
BFGoodrich G Force 235/40 Front Tires
BFGoodrich G Force 245/40 Rear Tires
Driveline:
Nismo flywheel
Exeddy Stage 2 clutch w/ high presure plate
Kaaz 2 way diff
Nismo Engine/Tranny Mounts
B&M Style short shifter
P2M Steel braided clutch line
Interior:
Personal Steering wheel
Red NRG Quick Release
NRG QR Lock (for steering wheel)
Sony MP3 Deck
Infinit Kappa Components
Sony 1000W Amp
Kenwood speakers rear
Exterior:
Custom body work (flared and rolled fenders)
Full Origine and Version select body kits....
Bomex Wing
JDM Kouki Grill
Seibon Hood
Seibon trunk(not installed yet)
Hella HIDs 3000k (yellow)
heres the link to my car build thread
#/f/showthread.php?t=156395
message me if you are intrested or send me a email [email protected]
one 2 many 240's and I just keep coming back for more
yaba94070 is offline   Reply With Quote
