Old 07-03-2012, 11:22 AM   #1
blades13.5
blades13.5's Avatar
blades13.5 is an unknown quantity at this point
A couple questions
I'm missing the plug that plugs into the back of the Valve Cover (circled in the picture) If someone could please tell me what that piece is called, thanks.
Also, I just bought the banjo bolt. The high Pressure Line fit perfectly into the Banjo Bolt. The bracket on the side of the PS pump held the banjo bolt in tightly. The hole above the banjo bolt that is supposed to go over the bolt and the adjacent hole on the power steering line seem the same size however the bolt that fits straight into the power steering pump is larger than both holes. do you think I may have an s14 or a KA PS Pump? any suggestions. Sorry if this question has been posted before but i have searched on my own and I hadn't found the answer I was looking for.
Check out my build! #/f/builds-builds-on...s13-build.html
blades13.5 is offline   Reply With Quote
Old 07-05-2012, 10:00 AM   #2
sk8rfreak345
sk8rfreak345 is an unknown quantity at this point
thats your pcv valve
sk8rfreak345 is offline   Reply With Quote
Old 07-07-2012, 10:03 PM   #3
blades13.5
blades13.5's Avatar
Thanks Sk8r! I just bought one on FRsport. Any idea about the power steering bolt? Is there a difference between the size of the bolt for an S13/s14?
power steering
