03-21-2009, 01:42 AM | #1531 |
LOL penetration is virtually a non-issue with sheet metal...
03-21-2009, 10:53 AM | #1532 | |
For like body sheet metal I have heard real good things about silicon bronze wire for bodywork since it is soft and easier to grind, and it has great anti-corrosion charactoristics. |
03-21-2009, 06:53 PM | #1533 | ||
I only mentioned the dual shield flux core to open up some closed minds about flux core. |
03-21-2009, 10:15 PM | #1534 | |
Here is a little somthing I did today... I have been working on re-designing my fender braces...I like these. |
03-21-2009, 10:46 PM | #1535 | |
I found out yesterday though that I have a 220V plug in my house that I can get access to in my backyard lol So I might look into a TIG welder eventually because I don't think you can MIG weld or flux core with thin aluminum pieces such as intercooler piping. |
03-21-2009, 11:02 PM | #1536 | |
Correct...about the thinest aluminum MIG welding I have had luck with is 1/16"...not saying it is not possable, just high skill factor. Now on to the TIG...Look at machines that are AC/DC and have HF start. You will be looking at machines $1500.00 and up. |
03-22-2009, 10:12 AM | #1537 |
this is nothing even close to what you guys are making, but it's a start.
I made a skid plate yesterday. Sheet aluminum .080" 2'x3' cost $9 at the local steel supply. It's nothing fancy, but it does the job and only cost about $14 to make. |
03-22-2009, 02:38 PM | #1538 | |
I like!
03-22-2009, 02:49 PM | #1539 |
Thanks dude. The bend was a little tricky seeing is I don't have the proper equipment. Being a carpenter I made a jig that attached to my workbench, took the heatgun, and away I went. Good way to kill an afternoon when we finally reached 60 degrees here in MN.
03-22-2009, 03:08 PM | #1540 |
Hey guys I put my S14 SR in my S13 using a dohc tb cable.
I have tried bending the stock bracket slightly since no matter how much I adjust it, after pressing the gas pedal it wont go all the way back down and stays revving a bit. Does anyone have any pics of a custom made tb cable bracket before I make a crazy looking one that is overkill? Searching was too broad... thanks!
The thing is, it’s a gearbox, okay? It has one job to do! One job! Pull the lever… ‘Am I a pencil? Am I a cauliflower? Am I a nuclear power sta– I’m a gearbox! Oh, heavens, I’m gonna swap some cogs around!’ Jeremy Clarkson on Automatics |
03-22-2009, 03:35 PM | #1541 | |
03-22-2009, 05:04 PM | #1542 | |
Do these do alot? I am seeing them more and more. Why exaclty to people have them? A substitute to stitch welding? I guess any extra strength helps, but i dont see a mjaor benefit of fender braces.
Left hand drive 240sx's ARE NOT SILVIAS. |
03-22-2009, 05:54 PM | #1543 |
Much stiffer than stitch welding. Only problem is, by stiffening the front even more, you induce even more understeer (my car already understeers, even with just stock sways). That's the only reason I haven't done it yet.
03-22-2009, 07:15 PM | #1544 |
ls1 y pipe and exhaust for my 240
now it is all tigged and tucked in. feels good to be gangsta. now its sway bar mod/fab time!
hydropgrahics! ls1...... |
03-25-2009, 11:00 PM | #1545 | |
Doesnt seem like a common problem so I will just fab one up I guess.
03-25-2009, 11:23 PM | #1546 |
Got to TIG weld some 4130 Chromoly tubes for a chasis at school, thats for a project. It was kinda scary at first but I got the hang of it. I'll try to remember my camera tomorrow and post up pics here.
I just really struggled with really tight spaces of the tubing. |
03-26-2009, 12:06 AM | #1548 | ||
Haha, I didn't cut that far back on the driver's side, and I did a lot of cutting from the "wheel well" side, not the engine side (fender off). Cutting is the easy part lol, but your templates look really good!
03-26-2009, 12:43 AM | #1551 |
Thanks. I had to cut that shit out on the driver's side. It was all rusted out pretty bad. Had to go down past the frame rail. I was pretty amazed at how well the HF spot weld drill bit worked too.
03-26-2009, 12:47 PM | #1556 | |
03-26-2009, 12:54 PM | #1558 | |
Dude, those welds are ridiculous for being done by hand... assuming the tubing is clamped down, how much do you do at a time? 180*? I can't see any start/stop pools... shit's rad. Oh, and the crossbar on your cage (roof to floor) looks like it's offset from the main hoop? Whats that?
03-26-2009, 01:48 PM | #1559 | |
harness bar is offset not the diagonal, I'm 6'1 260lbs just moved it back for a little extra room heres a pic you can see the tubes arent actually straight and you can see the only stop on the lower weld in this pic right side |
03-26-2009, 11:35 PM | #1560 |
Here's some of the welding I got done today from school.
We got the chasis already made from another team, but they're kart was for all motor. Ours is going to be electric/fuel so we have to alter the chasis for our setup. The pics shows the battery trays we made and welded up. We'll be welding up the supports for the motor tomorrow hopefully. I know the welds don't look that nice, but hey I havn't been welding for years lol I'm still noobish And yes there is some oxidation on the welds, I asked one of the welding instructors why that occurs, he said it's probably due to the moisture in the air. I'm running argon, enough. |
