![]() Join Date: Apr 2007
Trader Rating: (28)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 28 reviews
Scratch/dent HKS HIPERMAX IV GT S15/S14 $900 shipped
Fedex was a jerk and decided to dropkick some coilovers off their truck and damaged them... SO WE'VE GOT A DEAL FOR YOU! 900 shipped. All sales final, no returns.
The new Max IV sporty suspension. Awesome sporty drive with great control and comfortable ride in the street. It's perfect for daily street drive with style and performance. You and your passenger can have a comfortable ride even with a low-down. *Single Tube Damper Design* Mono tube dampers allow for more accurate and stable control and adjustment of dampening. Lower ride height and centre of gravity gives a more stable ride. *Dust Boot* Protect the shaft from the flying stones. *PNE Coating* Using this special surface coating provides 5 times better durability over standard galvanising. This prevents build-up around the threads of the adjustment areas allowing for easier height adjustment. *"M Shaft"* With the new design of cylinder shaft since the HIPERMAX M-1, MAX IV increased the cylinder shaft size to have a firm damping even at a little stroke range because of the optimized oil pressure characteristic. We mainly adopted this to the rear damper that can have a better driving experience. *New Design Needle* Newly designed needle has been used to revise the very low speed and middle and high speed dampening which is key to a comfort ride. *Reduction of Unsprung Weight* In order to reduce unsprung weight, bracket, ride height adjusters and lock nuts are made from aluminium. (Not for all vehicles) *30 Step Damping Force Adjustment* 30 levels of dampening adjustment allow fine tune adjustment for street or circuit. Damping Force (Front): 211m/sec (Rebound) & 137m/sec (Compression) Damping Force (Rear): 839m/sec (Rebound) & 382m/sec (Compression) Front Upper Mount: Rubber Lowering (Front): -47mm (From 0 to -81mm) Lowering (Rear): -45mm (From 0 to -80mm) Rear Upper Mount: Rubber Spring Length (Front): 220mm(Barrel) Spring Length (Rear): 250mm Spring Rate (Front): 59N/mm (6kgf/mm) Spring Rate (Rear): 49N/mm (5kgf/mm) ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
