Old 07-24-2009, 03:00 AM   #1
xxcivic96xx
xxcivic96xx's Avatar
xxcivic96xx is an unknown quantity at this point
KA stock ka-e cuts out at 3500 rpm
i was driving on the freeway and i was in 5th gear at around 3500/3600 rpms the engine cuts out.
it wont go anymore until i push the clutch in and then release it again,or when i let the rpm's go back down below 3000rpm
it will only happen in 5th gear and right around 3500 rpm.
any ideas of what to look at? any suggestions will help
thank you
xxcivic96xx is offline   Reply With Quote
Old 07-24-2009, 03:00 AM   #2
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
Only happen in 5th?
Check MAF yet?
SochBAT is offline   Reply With Quote
Old 07-24-2009, 03:57 AM   #3
let5l1de
let5l1de's Avatar
Trader Rating: (30)
let5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfection
Feedback Score: 30 reviews
Send a message via AIM to let5l1de Send a message via Yahoo to let5l1de
my 89 coupe had the same problem when i first got it. I think it had something to do with 1 of the trans sensors... maybe 5th gear or speedometer wire.
~mario
**GR Performance facebook** Pics & More! Comments! http://www.facebook.com/pages/GR-Performance/120477531339202
Read My Sales Review
626 Friday Nights San Gabriel
let5l1de is offline   Reply With Quote
Old 07-24-2009, 04:20 PM   #4
xxcivic96xx
i checked the maf and it works fine
and yes it only happens in 5th gear...trans could be a possibility
could it have something to do with egr? because i am cruising with the CEL off and i get it up to 3500 and then it cuts out and then the engine light turns on. i check the code and it says egr
Old 07-24-2009, 04:23 PM   #5
nrmskate
nrmskate will become famous soon enoughnrmskate will become famous soon enoughnrmskate will become famous soon enoughnrmskate will become famous soon enoughnrmskate will become famous soon enough
Is EGR the only code you got?
EGR shouldn't effect that.
nrmskate is offline   Reply With Quote
Old 07-26-2009, 06:43 PM   #6
xxcivic96xx
yeah just the egr code would show
isnt there a fuel shutoff if the egr is closed past a certain rpm?
today i was driving and the cel was off,so i tried to get rpm's up to see if it would do it and right at at 3500 it shut off and the cel came on again.then it smelt real weird
...5 mins later the cel turned off so i tried it again and it went up to 4000 rpm with no problem. (all of this was in 5th gear)
Old 07-26-2009, 06:53 PM   #7
aziankingz
aziankingz's Avatar
Trader Rating: (28)
aziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really nice
Feedback Score: 28 reviews
im having the same issue but cuts off at 3500 at 4th and 5th gear.. i believe my issue is the speed sensor but not quite sure - does your speedometer work?
aziankingz is offline   Reply With Quote
Old 07-27-2009, 03:36 AM   #8
xxcivic96xx
what difference would that make?
and it works off and on...most of the time not :/ does yours?
Old 08-08-2009, 08:50 PM   #9
aziankingz
aziankingz's Avatar
Trader Rating: (28)
yeah mine does it only when the speedometer stops working..
Old 02-24-2011, 07:57 AM   #10
Kr240sx
Kr240sx's Avatar
Kr240sx is an unknown quantity at this point
Digging this one up!
My Car is in the same boat when the speedo isnt working it cuts out. Has anyone figured out if its the speed sensor or an alternative solution?
Kr240sx is offline   Reply With Quote
Old 02-25-2011, 10:24 PM   #11
frosti108
frosti108 is just really nicefrosti108 is just really nicefrosti108 is just really nicefrosti108 is just really nicefrosti108 is just really nicefrosti108 is just really nicefrosti108 is just really nicefrosti108 is just really nice
Send a message via AIM to frosti108
speed sensor no doubt
Goodnight
frosti108 is offline   Reply With Quote
Old 02-25-2011, 10:30 PM   #12
[email protected]
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
mine used to do that. when my cluster didnt work, it would cut out at 3500. changed my cluster and it worked perfect
R@ddy is offline   Reply With Quote
