![]() Join Date: Feb 2002
Enjuku Racing - VooDoo13 Front Tension Arms *IN STOCK*!
![]() VOODOO13 FRONT TENSION ARMS FOR NISSAN 240SX In Stock and Ready to Ship! $207.00 ![]() ![]() ![]() VooDoo13’s 1989-1994 Nissan 240sx S13 Front Adjustable Tension Rods are designed, engineered and tested on race tracks across the globe using feedback of top tier drivers and technical directors. Precision CNC machined body from high strength 6061-T6 aluminum coated in MIL-A-8625 Type III Hard Anodize, CNC’d chromoly hardened steel adjuster, stainless steel CNC machined spacers and Grade 8 hardware are used to ensure they will withstand abuse from street cars and track cars alike. We use QA1 XM Chromoly Steel heim joints that are heat treated for strength and durability. The spherical rod end is self-sealing and self-lubricated because of their Nylon/PTFE injection molded race that keeps out dirt and debris. These tension rods are engineered specifically for optimized shape and geometry for maximum steering angle. Includes pair of Tension Rods, misalignment spacers and Grade 8 hardware. All of our products are engineered, manufactured, and assembled at the Gilbert, Arizona facility using only the best materials from US suppliers. ![]()
