93 300zx misfiring
Ok got a problem with my 300zx i put a new timing belt on and the hole 9 yards with it.Timing marks set perfect.but now that its all done its missfiring started up fine any ideas of what this could be.
Have you checked your connectors on the injectors? Or maybe the PTU? I had the same issue and found the connectors had a lot of corrosion. Cleaned the up with a pick set and electric motor cleaner, then put some dielectric grease on after.
It may be bad injectors...O-rings tend to go bad after awhile..Relatively easy fix. Z32's are notorious for having injector problems. I agree with daxnismo on the injector ends. I would check those first, and if any or some or bad it's not hard to install new connectors.
