For SALE:
Brand new wiring Specialties ls1-s14 harness (t56/MAP/ls1 accessories) (new) - $600 Ceramic coated peak boost bottom mount turbo manifold - $350 Apexi power intake (BNIB) - $125 S13 sr20det front oil cover (like new) - $125 Dual Altima e fans modified & with brackets for s14 - $85 (pick up) Competition clutch lightened flywheel (10.8/11lbs): $275 (brand new) (BNIB) spring 6 puck ACT clutch (good for 550 lb/torque) with (used) RPS Pressure plate - $350 Bling black coil pack cover - $55 S14 brake master cylinder and BMC - $125 Z32 17/16 BMC - 85 S14 rear sway bar - 50 Sr20det/ka solid aluminum motor mounts - $125 Stock s14 wheels - $100 S14 front sway bar - 50 Gktech front sway bar links - $50 (new) S14 rear oem brakes with pads & rotors - $75 S14 front brakes with pads & rotors - $75 S14 non abs DS - $70 S14 stock arms - make offer (i have most arms available Sr20det OEM starter - $125 (good working condition) All shipping costs and fees are covered by the buyer! Last edited by SidewayzAsFck; 10-21-2019 at 12:12 AM.. Reason: Few things sold and added |
| act clutch, cd009, competition clutch, sr20det, turbo manifold |
