![]() Join Date: Aug 2004
![]() ![]() ![]() Feedback Score: 9 reviews
Just swapped gauge clusters, now speedo n fuel gauge isnt working?
Just spend my time swapping my gauge cluster because my old one the gas gauge was goofy.Anyway.. I had another cluster laying around that was in decent shape although I never used it I don't know if it worked so... I put my speedometer and tach from my current gauge cluster to the one I'm gonna swap it with cus the needles were in better conidtion. To do so I had to take out the sensor in the back that links from the mileage to the speedometer. Once I went ahead and put the cluster in after it was swapped everything works but the speedo and fuel gauge? The speedo is not resting on the lil lever.. its stuck on like 5mph. And doesn't move. Also the fuel gauge doesn't work on the ner cluster.. its sitting on a quarter tank and isn't moving at all.. drove it 20 miles and it hasn't budged? All the plugs were securely plugged in? What could it be? The speedo worked fine in my other cluster? And the gas now is stuck?
a silvia
anybody??? Put gas in it and it actually went up but it went up from where it was hanging at... n car was empty at the level it hang at. Do u have to reset something to get it reading right?
a silvia
