![]() Join Date: Feb 2002
*NOW IN STOCK* $1,199.99
![]() _________________________________________ The GT2871R is the newest in Garrett GT technology. Dual Ball Bearing GT2871R turbo assembly with T25 style turbine inlet. Comes with internal wastegate pre-assembled when purchased with T25 style housing. This turbo will produce 360 horsepower to the wheels in an SR20DET equipped with the right supporting modifications. Full boost can be realized as low as 3800 rpm with the .64 a/r T25 style exhaust housing. ** Does not include Wastegate Actuator or bracket - Reuse of stock actuator required ** _________________________________________ Click here to order ===> http://www.enjukuracing.com/products...bocharger.html
Just PMed you a quote. Thank you for your inquiry.
