![]() Join Date: Dec 2004
Trader Rating: (58)
Greg Dupree Subframe Bushing Spacers - 40 shipped
Part: Greg Dupree Subframe Bushings
Price: SOLD Shipping: Same day if paypalled before 12 Noon EST, or morning after. These are packaged, ready to ship. Upgraded the entire rear supframe of my car, and converted to the press in ES bushings all around. No longer need these! These help reduce antisquat as well as wheel hop. These are literally a 30 minute install for even those with the most basic tools. If your subframe bushings are good, these are a fantastic way to preserve them, while gaining a positive suspension modification that helps on track and on street. To install, all you will need to do is remove (one at a time) the subframe stud nut, remove the OE metal washer cup, place the spacers on the OE bushing, and then reinstall the metal washer and nut that you just took off. Remember, if you live in a rust belt state, to use PBlaster or WD40 on the threads, as a preventative measure, as well as to make install easier. SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD
![]() Want Air Conditioning in your SR20 Swapped car? Check out www.sr20acbrackets.com for more information! Quest Alternator Conversions for SR20! Check my Group Buy! Tired of lousy internal gates? Go external wastegate with one of my manifolds, Check out my group buy Last edited by codyace; 02-03-2010 at 03:26 PM.. |
Trader Rating: (58)
Pm Responded. I'll be in your area this weekend for Army Drill, so whenever you want to swing over that's great. (Usually just after or just before lunch works out best, that way there aren't any formations/assemblies)
If ehhhregartless doesn't pick these up this weekend, I'll PM you my information and have them heading your way ![]()
Trader Rating: (58)
Thanks again!
