![]() Join Date: Mar 2009
R33 calipers, need some help.
So I decided since I have no abs I might as well grab some better calipers....so I look on ebay and I find a nice near new looking set of the sumitomo calipers. I thought all the 4 pot calipers are the same....little did I know the R33 front calipers use a larger rotor...of course I found this out after already hitting buy it now
the exact specs the R33 GTST uses is 296mm diameter x 30mm wide. I know the rear calipers and rotors are the same as a Z32 though. My question is will the Z32 front rotors work with those calipers...they are still 30mm but are 280mm diameter. On many after market sites I see the brakes for the z32 and R33 are the same part #. Any one ever experience fittiment issues with R33 calipers using a z32 rotor?? Just wondering b/c those 296mm rotors are sort of hard to come by in 4 lug. |
![]() Join Date: Jul 2005
Trader Rating: (354)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 354 reviews
Dont try using the Z32 rotors instead do what MrMcGarett did here:
#/f/sale-items/27028...-calipers.html I can vouch that they work. Just drill the rotors to 4 lug and you are done. |
#9 | |
R.I.P. Aya, always love
![]() Join Date: Nov 2001
Trader Rating: (215)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 215 reviews
R32GTR's use a 296mm x 32mm rotor! I know I owned them and ran them. Oh and finding rotors for them is tricky because of the width vs diameter. Z32 Rotors will not work properly because though the Z32 rotor is only 2mm thinner its a whopping 15mm smaller in diameter. Z32 rotors are 280mm x 30mm As far as running a 350Z rotor goes,why? It would be larger diameter wise for your caliper, though technically not worth doing because you are not utilizing the extra surface area of the rotor because the caliper will cover it.
"Having a lot of tracks on a song is like putting stickers on a car to get more horsepower" New Video https://www.youtube.com/watch?v=uebV1OnbRsw Buy my mounts! #/f/sale-items/51531...ns-mounts.html #/f/tech-talk/317539...e-mouts-6.html |
Infiniti Q45 240SX Drilled & Slotted Front Brake Rotors : eBay Motors (item 370334485716 end time Feb-21-10 23:30:25 PST)
I believe this will be perfect for me....and really cheap too I am going to see if I can get the rear z32 rotors redrilled to 4 lug by the same ppl |
btw these calipers i bought look almost new
![]() i did some research and supposedly these calipers will fit under the stock 240 alloy wheels with a spacer....anyone know how big of a spacer I would need?? 3mm?5mm? |
#12 | |
![]() Join Date: Sep 2006
Trader Rating: (313)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 313 reviews
You need the 97-00 Q45 rotors. |
in case anyone was looking for a setup for 4 lug R33 calipers I found a seller on ebay that will do the 01 q45 front rotors z32 rears and z32 f/r pads and even redrill them to 4 lug. Pm me if you want to know where to get them
Just got my calipers in....damn these things are meaty as fuck! I didn't realize how wide they are....porbably going to need a5 least a 8mm spacer for my stock alloys to fit them. So I got my brake lines and calipers....just waiting on the rotors and I still need to get an ebrake assembly
I wonder how these huge as brakes will be without abs.... |
