Sr20 redtop, No boost. help please
Hello, I'm fairly new to the turbo car world lol. I've always wanted a 240sx and i finally got one with the sr swap in it but it still needs work.
Down to the story i was changing the turbo coolant/oil return lines to DIF lines and after i took off the Exhaust manifold i saw the gasket was broken in half idk if this is my problem but after i put it back together my car bogs down while i WOT it. It reads boost and the turbo spools healthly so its not a bad turbo. I am planning on ordering a new Manifold and MAF. |
![]() Join Date: Nov 2013
Doe you have a leak in any of the seals?
Sent from my SCH-I535 using Tapatalk
'91 s13 (Drift Rocket Under Construction) 2000 civic Si Coupe (Daily) |
I don't believe so, if you're getting boost pressure then I would say no. Do you have stock fuel pump? Stock Ecuador?
Ecu^ stupid fucking phone
That's what I'm saying though, are the seals around the turbo or the tubing itself sealed? You could also be in limp.
My guess is you're losing pressure somewhere. Sent from my SCH-I535 using Tapatalk
What part of the Wood are you in?
First, stop trying to boost the car. There is obviously an issue and you don't want to damage anything. Second, you were in there messing around. Check all connections, make sure you don't have a rag shoved some where, basically double check everything. Have you done any matienence on the car? Have you changed oil, filter, plugs? Let's start with the basic stuff such as spark plugs, ingnition timing, etc.
My SR20VET |
#15 | |
I live in the Sarasota county side of Englewood near dearborn. |
What's ignition timing? -_-
#17 |
Ignition timing, when the number one cylinder fires it's spark... It should be at 15* BTDC. Perhaps you should download a factory service manual(FSM) and do some reading.
My SR20VET |
#19 |
We all are start somewhere and the only way to learn is to ask. There's no such thing as a stupid question.
I was just a little surprised you didn't know what ignition timing was with an sr20 swapped 240. That car is intermediate, not beginner level. Sent from my SCH-I535 using Tapatalk
#20 |
![]() Join Date: Dec 2004
Trader Rating: (58)
Did you remember to hook the wastegate vacuum line back up?
#22 | |
Came with coilovers, sr20, manual boost controller and a bit more. I just took over the project, I have alot planned for it. lol |
#23 | |
Also always remember: one mans unfinished project is another mans headache. Sent from my SCH-I535 using Tapatalk
#24 |
Trader Rating: (58)
plmsdevelopments.com/sr_setup_tips.shtml
Follow that to set the car up, this helps get all sensors sorted/back to OEM
#27 |
There are a few locals that frequent this site. Username Tom N and I are both close by if you have serious problems or can't figure it out.
My SR20VET |
