I started a f/s thread a few months back but had to take it down because I couldn't pull the parts with all this snow and got overwhelmed with the requests. Everything is out of the car now and back up for sale. The car made 730whp with an estimated 800 at the crank on pump e85. Total mileage on the swap is roughly 1500 miles. Oil changed every 250 miles. I'm going the 2JZ route and no longer need these. Below is a list of parts and if you want more info just let me know. Text me for a quicker response or if you need more pics (201) 406-1760. Prices firm. Paypal add 3%. Located in NJ. Thanks
S13 Sr20det, k-series coil packs $100, BC valvetrain (264 cams, valves, retainers, springs, ect.) Head has 3 missing rockers, BC cams SOLD, $300 for the head s13 sr20det bottom end, 8.5:1 CP pistons, Eagle h beam rods, arp 2000 studs - SOLD Exedy Single Disk Clutch and flywheel - SOLD, sr20 to300zx (z32) transmission adapter plate - SOLD (includes trans mount and shifter bracket) 300zx (z32) transmission with upgrade hd fork - SOLD 300zx to s13 transmission shifter bracket, trans mount - SOLD (adapter plate included) ATI damper pulley - SOLD Greddy 5qt oil pan - SOLD Custom electrical plate for use with harness (see other pic)$500, AEM v2 with JR tune (unlocked) - SOLD Custom mil-spec engine harness (wired for k-series coils, id2000 injectors, ect. PM me for details) $500 (electrical plate included) E85 compatible fuel lines (complete from pumps to rail) $250 Exhaust up-pipe with or without aem wideband - SOLD Big plenum custom intake manifold - SOLD Accufab 90mm 5.0 throttle body - SOLD Oil cooler and lines - SOLD Precision V-band (6466) 66mm t3 exhaust housing only $200 oil feed and drain lines $50 Peakboost exhaust manifold (wastegate not for sale) - SOLD Sard fuel rail - SOLD z32 transmission mount and shifter bracket (included with adapter plate) - SOLD Mishimoto radiator with fans and s13 hoses $300 Driveshaft shop aluminum driveshaft - SOLD z1 short throw shifter - SOLD s13 sr20det solid motor mounts - SOLD t3 turbo blanket - SOLD another exhaust up-pipe with wideband - SOLD coolant resevoir - SOLD big Garrett front housing $80 stock s13 cams, coil packs, ignitor, chain and tensioner, pulley spare s13 block $150 K-series (k20) coil packs $80 s2000 gauge cluster - SOLD ID1000 injectors - SOLD Oem sr20det headgasket $50 Also not listed is all the 3" intercooler piping - SOLD, as well as another z32 transmission but wont go into 5th $100 :::CLICK HERE FOR VIDEO:::: :::CLICK HERE FOR VIDEO:::: Last edited by kamilpl; 05-12-2015 at 08:14 AM.. |
![]() Join Date: Aug 2013
Please post prices, per forum requirements. Dont want to see this get locked up. Good stuff here.
#24 |
