![]() Join Date: Feb 2002
Enjuku Racing - ECUMasters EMU Plug and Play Standalone ECU for Nissan RB20/25/26
![]() ![]() ECUMasters EMU Plug and Play Standalone ECU for Nissan RB20/25/26 In Stock and Ready to Ship! $1274.00 ECUMASTER EMU Plug and Play is a complete plug-in standalone ECU The Engine Management Unit controls all aspects of the engine, and offers failsafe strategies in case of sensor failures or other events. The EMU features more built-in value than anything else on the market, not requiring any external modules to drive up to 6 passive coils directly (up to 12 smart coils), a Bosch LSU 4.2 O2 sensor, 2 EGT probes, a Flex Fuel ethanol content sensor directly. The inclusion of a built-in 4 bar MAP sensor further adds to the value of the EMU. ![]() Using the latest technologies in the fields of electronics and software, the ECUMaster EMU has the latest features and an attractive price at only $1200. As an introductory offer, a Bosch LSU 4.2 O2 sensor is included with every EMU purchase. Common applications for the ECUMaster EMU are modified sports car and racing engines, motorcycles, boats, and stationary engines. ECUMaster EMU Technical Details 6 Fuel injector outputs (5A) (12 injectors in batch fire) 6 AUX outputs (5A) 6 Ignition outputs -Passive or active coils, software selectable (7A) (supports up to 12 cylinders) 4 stepper motor outputs – bipolar/unipolar (1A) 2 direct EGT input channels 2 knock sensor inputs (supports flat response or resonant sensors) Built-in wideband O2 controller for Bosch LSU 4.2 Built-in 4 bar MAP sensor Built-in barometric pressure sensor 4 Digital inputs VR/HALL – software selectable 3 Dedicated analog inputs (TPS, CLT, IAT) 4 Additional analog inputs (0-5V) Compliance with ISO 7637 Supports 1-12 cylinders Max RPM 16000 Injection time resolution 16us Ignition advance resolution 0.5 deg Knock sensing 1-20 kHz Speed Density, Alpha-N algorithm 16×20 VE fuel table, resolution to 0.1% VE 16×20 Ignition table, resolution to 0.5 deg 16×20 Target AFR table, resolution to 0.1 AFR Injector voltage compensation Coil dwell calibration User calibrated IAT, CLT PID idle control strategy PID Boost Control, advanced strategies: per gear, per speed Nitrous control with fuel and ignition modification tables Aux outputs for fuel pumps, radiator fans, etc. Motorsports features: launch control, gear dependent shift light, flat shift ( gear change cut) Logging available for over 100 parameters Check engine light output Full Flex Fuel capability with map blending (requires ethanol content sensor) Advanced features available with additional modules: Drive By Wire throttle, Bluetooth adapter for using an Android device to display gauges USB communication, no additional interface needed, uses standard USB cable (included) The ECUMaster EMU comes with user friendly software with free firmware upgrades 24 month warranty PC Requirements Windows 2000, XP, Vista, Windows 7, Windows 8 Screen resolution of at least 1024×768 16bit CPU with a clock of at least 600MHz USB port What’s in the box ECUMASTER EMU computer USB cable Plug and Play Adapter Bosch LSU 4.2 Wideband O2 Sensor and Harness CD with software drivers and manuals Laminated pinout of terminals on the ECUMaster EMU
Office: 352-241-8399 / 1-888-SR20DET (772-0338) YouTube.com/c/EnjukuRacingParts http://www.enjukuracing.com questions@enjukuracing.com ![]() |
