✰✰ Buddy Club Junior Spec Dampers (S13) ✰✰
Buddy Club Junior Spec coilovers for the S13 Silvia/180SX. This set is used and in good condition with no leaks or bends and all dampers compress and rebound correctly. Features include adjustable camber plates, pillow ball upper mounts, high-strength inverted monotube front struts, 15 way damper adjustment, and a full-tap design (double adjustable) to allow for extreme lowering without effecting spring pre-load. Spring rates are 8kg/mm (front) and 7kg/mm (rear). Please note that the standard rear springs have been replaced with Ohlins springs rated at 8kg/mm. Please note that two of the "teeth" have been worn off of the lower lock ring on the rear coilovers. The other teeth are intact so they can still be turned easily. Price: SOLD These can be purchased instantly from our website at GTR Garage. If you have any questions don't hesitate to send us a PM or email.
www.gtr-garage.com Last edited by GTR-Garage; 07-28-2013 at 08:22 AM.. |
These are now sold.
www.gtr-garage.com |
