![]() Join Date: Nov 2003
SR20DET Part Out (GTX, JWT, CAS, Flywheel, o2, TPS, crank pulley, IACV, driveshaft,
Alright, here is the near full part out thread, if you need something else, let me know I probably have it. All parts are in perfect working condition, some even are brand new, others less than 5k miles on them.
All prices are OBO and don't include shipping, will offer discounts for groups of SR20 parts. SR20DET Parts for Sale: *JWT ECU (740cc/Z32): $325 *Walbro 255LPH fuel pump (3 years old): $35 *Tomei -6 AN Fuel Rail Adapter: $20 *SR Flywheel: $65 *Transmission (needs work): $25 *Ignition Coils with harness (2x harness, 3x coils): make offer *Coolant Temp Sensor (blue less than 1k miles, red used): $20 each SOLD LIST Crank Pulley with BNIB OEM Front Main seal: $75 SOLD Throttle body with brand new TPS Sensor: $50 SOLD Knock Sensor with harness: $35 SOLD Idle Air Control Valve (IACV): $50 SOLD GTX2867R Complete turbo kit: $1800 SOLD Cam Angle Sensor (CAS): $100 SOLD Clutch Fan Assembly with Shroud: $50 SOLD Z32 TT Maf (N62): $100 SOLD Starter: $75 SOLD NISMO Motor/Trans mount kit: $125 SOLD S14 Water Neck: $65 SOLD Power Steering pump w/ bracket (1k miles on it): $50 SOLD Quest Alternator Upgrade kit w/ CodyAce bracket: $125 SOLD Samco Radiator Hoses (near new): SOLD Alternator (stock with aftermarket pulley): $50 SOLD JWT ECU (740cc/Z32): $350 ![]() -6 AN Fuel Rail Adapter: $25 ![]() SR Flywheel: $75 ![]() Coolant Temp Sensor (blue less than 1k miles, red used) $20 each:
-Kyle Last edited by BlackZenkiS14; 01-04-2016 at 09:58 PM.. |
#4 | |
Clutch pic: ![]()
-Kyle |
![]() Join Date: Dec 2004
Trader Rating: (58)
bump for a bad ass setup!
Hey thanks buddy, I'm honestly bummed to be changing drivetrains after all the work spent, with your help, near perfecting this thing. It was a blast.
-Kyle |
bump for a nice setup, that PE intake is no joke kept my maf spotless with 25psi constantly for 3 years best intake on the market IMO
#13 | |
PM's replied!
-Kyle |
#19 | |
o2 Sensor (3 months old) less than 1k miles. $35, (40 shipped)
-Kyle |
#28 |
It's a MAF based ECU, so it sets fuel and ignition parameters based on airflow and throttle load, just like OEM. This means you can run most any turbo and set of cams with it. As it'll just adjust for the increased airflow automatically. You just adjust fuel pressure slightly to fine tune it.
I have run S14 T28 with stock cams, and GTX2867R with JWT S3 cams, it ran perfect, as this is how the ECU is designed to work. They relcalibrate for the injector and MAF size, and let the ECU do the thinking for the rest like normal. I have a buddy running this same ECU on his GT30 car with 264BC cams. You can ask JWT, this is what they designed their ECU to be. Because of this, it's the most reliable, and consistent and maintains 100% street ability and driveability. And you don't have to worry about a retune everytime you change parts around. What's your setup though? I can give you an idea of whether or not it would work fine.
-Kyle |
