I know I just read a thread with someone having the same issue or something pretty close but when I go to start the car you can hear the fuel pump prime and my radio and dash lights come on but I get nothing from the starter you can hear the ignition relay click also I checked the power the starter and it has 12.4 volts. I even jumped the starter and you can hear the starter turn over but it turns over slowly. Right now I’m guessing there's a short between the ignition relay and the starter or I need a new battery any suggestions?
![]() Join Date: Sep 2008
If your battery is pumping 12.4 volts it should be fine.
Was this a swap you just did and your having this problem ? Or have you had this setup for awhile and suddenly have this occur ? If you put power directly to the starter from the battery and it cranked slowly there may be excessive resistance on the crank. Like somethings tigher in there then it should be. But if your sure its not that, then its electrical. When you say jumped the starter are you sayng you directly hooked up the battery to the starter leads ?
1994 toyota supra...... n-a D= 1992 nissan 240sx KA24E-T fully Built =D |
[QUOTE=BoostSlideWayz;5654722]If your battery is pumping 12.4 volts it should be fine.
Was this a swap you just did and your having this problem ? Or have you had this setup for awhile and suddenly have this occur ? I had a similar issue with my sr20 mine ended up being a leaky injector I guess wen the fuel pump would prime the fuel rail the injector would already be leaking causing my cylinder to fill with fuel and the car wouldn't crank over because the cylinder can't push the gas thru the rings I also thought it was my starter cause it wouldn't turn over but you can Check for this its real easy just pull the spark plugs and check for fuel hope this helps. |
I jumped the started by using a screw driver and the swap was already in my car I just rebuilt the motor and now this I really don think something is too tight I'll check that once I'm off work
I fixed the starter problem but its turning over but still not starting you can hear the fuel pump prime and i know its getting fuel to the injectors but i dont think im getting spark. do you need to have the ignitor chip grounded? also where would i test to see if the coils are getting power?
