Old 04-19-2013, 05:35 PM   #1
wrxkid950
wrxkid950 is an unknown quantity at this point
bad diff? need some help
Ok so i have a 95 base and im new to 240sx and rwd. ok so this is my issue: when i make right turns its fine, i can go around a turn fast and the back end slides out fine. now when i make left turns heres the problem. unless im going real fast and take a turn hard, it seems like the back end is skipping across the road. feels like its binding up. its like a studder in the rear. thats the best i can explain it. now my question is , is that a bad diff? or could it be something else. only happens on left turns. any help would be appriciated
wrxkid950 is offline   Reply With Quote
Old 04-19-2013, 07:23 PM   #2
zerodameaon
zerodameaon's Avatar
You have an open diff, the tire with the least traction is getting the power. Nothing is broken it is just how these diffs act. You might have some suspension issues causing a tire to hop but that is not because of the diff.
Need to adjust your idle?
#/f/s-chassis/395413...-pictures.html
Old 04-19-2013, 07:24 PM   #3
wrxkid950
Ok thanks. Any idea on what kind of issue it could be?
Old 04-20-2013, 08:48 AM   #4
wrxkid950
any one else have some input on this? i want to know if i need to buy a new diff or what part of the suspension would cause it to happen only when i turn left
Old 04-20-2013, 08:55 AM   #5
Driftpretty
Driftpretty is an unknown quantity at this point
make a video.
just cause your cars crappy, doesnt make it a missile
Driftpretty is offline   Reply With Quote
Old 04-20-2013, 09:00 AM   #6
wrxkid950
yeah ill try to do that.
